Question about Home
How to remove a sink, sealed with silicone
How can we remove a sink, sealed with silicone rubber sealant, off a granite vanity top without wrecking anything?
  • 6,674 Answers
Try using a long piece of dental floss, like a saw, all the way around until you cut through the silicone.
Posted on May 26, 2010
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
Existing vessel sink is stuck to polished granite vanity top. We want to replace the sink with a different one but can't get the sink to release--we originally used silicone adhesive and have tried wedging...
Silicone is an excellent adhesive once it is fully cured. I would not try to pry it off but I would suggest that you take the blade out of drywall or utility knife and carefully try to cut through it. It probably will take several cuts to get the old basin free but thats the only way I can think of to do it without damage to counter top. Hope that helps. Thanks
Nov 13, 2010 | Buck 31" Granite Vanity Top for Vessel...
I can't get the faucet to not move from side to side after it is tightened donw on the granite vanity top. The base is tight and does not move, but the faucet part still moves a little. How can this be...
The faucet should have come with a rubber gasket which goes between the faucet body and the granite top. Make sure it's properly aligned and has not slipped out of place. Be carefull when tightening the faucet to the granite, since granite is easily cracked.
Aug 10, 2010 | Moen 6102AZ Kingsley Single Handle...
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
Is this sealed?
All of these counter tops are pre-sealed at the factory. This is the deck and back splash only.any side pieces that may have been put on, while sealed individually are generally caulked to create a sealed unit.
Feb 15, 2010 | Pegasus Technologies Pegasus 25 In. Black...
Installing sink strainers on a pegasus composit sink. Plumbers putty or silicone?
Us a clear sanitary grade silicone
The Plumbers putty will do the trick but it needs cleaning off very carefully where as the clear silicone blends
Sep 24, 2009 | Pegasus Technologies Pegasus 25 In. Black...
Wrong product on granite surface
Contact the company on the bottle! I would also talk to the store manager there as well. The manufacture will give you the correct steps in removing the product. You could also contact an installer and get some ideas as what can be done to either fix it or remove it. Either way, be careful. Most people don't realize that granite can be damaged.
Mar 30, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
What to use plumbers putty or silicone on strainer basket rims installed on granite sinks
you always use plumbers putty on the strainer baskets. you can never use to much just remove the access when tightened. If you use silicone you will have leaks withen a year.
Mar 24, 2009 | Pegasus Technologies Pegasus 25 In. Black...
My Linkasink is leaking at the bottom edges.
You need to seal from the outside edge and I would use a clear silicone made for use in wet conditions. It wouldn't hurt to put a bead around the bottom edge as well.
Mar 22, 2009 | Linkasink Square Magic Sink - Tray...
Home Logo
550 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
