Question about IBM ThinkPad G40 2388 Notebook
I installed win XP over the old win XP operating system , when completed, everything worked except the (ACCESS IBM) and volume control BUTTONS.pressing them gets no responce at all
  • IBM Master
  • 1,606 Answers
You need to install the drivers for those. Xp will try to use the existing driver if it can or use drivers that it comes with. Certain functions such as hot button or other hardware specific stuff will need the driver from the manufactuers web site.
This is the download and support page for the G40.
You should save that off in case you need something else. You may find that some things will not work or work as well if you don;t use the IBM/Lenovo driver versions. I think what you need are the hotbutton drivers and mayb keyboard customizer. Those are in the system utilities section. Download, save to desktop or other place and run them to install.
http://www-307.ibm.com/pc/support/site.wss/MIGR-50513.html
Posted on May 26, 2010
Touch volume control
Hi Friend,
Kindly let me know the make and model# of the laptop/desktop you are using so that I can provide you the direct link to install the drivers for the same.
Also, please mention the Operating system (OS) you are using, is it Win XP, Win 7, Win 8
Oct 18, 2013 | LG Computers & Internet
Hi I am printing barcode labels on a Zebra Tlp2844-Z. I can print resident barcodes in passthrough mode using the old Zebra driver (1.0.0.43) but the barcode does not print using the ZDesigner driver...
Have you tried creating the barcode / label using the ZDesigner software? It is available free on their website and I'm sure you'll find it easy to use. Hope this helps!
Aug 23, 2011 | Zebra TLP 2844-Z Thermal Label Printer
ProductName=Agilix GoBinder Version=1.0.3156 OSVersion=Microsoft Windows NT 6.1.7600.0 No Service Pack Installed (NonTabletPC) Details=Exception from HRESULT:...
get the correct version for win 7 operating system
each operating system is designed to run with certain win operating systems and will not run with any not listed
Apr 09, 2017 | Franklin Covey PlanPlus 4.0 for Windows XP...
I have installed Win 7 ultimate and after i have installed win xp sp3 in different drive. But now at booting the computer dosent show the operating system choice but instead win xp starts as the default...
When installing different versions of Windows, you must start with the oldest system first.
1. Booting from XP disc, create 2 partitions before installing and install XP to one of them.
2. After XP is complete, install W7 to second partition and after it is complete you will be given the OS System Boot choice at Start Up.
Regards,
Selk
Mar 27, 2011 | Computers & Internet
Volume Wheel, Headphone/mike/line in jacks not working
hi, try to install the LaunchManager aplication and touchpad (Synaptics) driver. It is avaiable at acer.co.uk, service & support, select the model, the select windows xp professional x32 as your operational system...
Jul 24, 2009 | Acer Computers & Internet
IBM ThinkPad 600E trying to put os on it
that is correct.. IF you are using windows 2000 the files are NOT the same as the files under XP.. Your best bet is to EITHER install the complete XP or find the win2k installation disk,, even an upgrasde disk for win 200 can be found probably around 100.00. IF the system isn't booting from your XP disk IS Your disk an ORIGINAL or a copy of the original?.. If for example your CD rom is drive E then see if you can find a win XP emergency boot disk and access the CDROM goto e:\windows\i386 then run the setup program, many cases this will overwrite your existing OS.. but do so at your OWN RISK I will not be accountable if you lose any of your important files.. some win98 emergency boot disks can access the cdrom but you may have to make certain additions to the autoexec.bat and/or config.sys files. be careful when using DOS because you can completely delete EVERYTHING on the HDD if you use the right command(s). As A DOS BABY I have performed many lazarus miracles but I have been using dos since the early 70's
May 22, 2009 | Computers & Internet
Lost my right as administrator
You have done big mistake that's why you are getting problem.
1)Regarding installation of win XP over windows vista.
You have to install first lower version and then higher version i.e. you should install first win xp and then windows vista. But vice-versa you can't do it.
So my suggestion is that format your c drive then install win XP
after installation win XP install win vista.
2) which operation system do you want to open .
You can remove it using windows tweak utility software wich is freely available on most of the website. Also you can manually edit it.
For manually do this.( i m not sure about windows vista it is available or not)
right click on my computer->click on Advanced Tab->setup and recovery framework click on settings->click on Edit button
You will see the boot.ini file. You can remove the windows XP line from that file.
Oct 22, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Replacing windows XP
Dear ashwagosha If you replace or upgrade your os the nothing to worry to remove privious version do one thing:-right click on your my computer icon - properties- click on advance tab- go on startup and recovery-setting-select default operating system-edit-delete the old operating path file and save it. bye
Sep 26, 2007 | Microsoft Windows XP Professional With...
IBM ThinkPad G40 2388 Notebook Logo
117 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
