Faulty Amstrad dd8904 VCR
Hi
I have a Amstrad double decker VCR model dd8904.
Fault sympton is when the unit is turned on it livens up and after around 30 seconds shuts done and flashes the Tape symbol on the no1 drive. When this occurs then the unit is not able to be operated.
Wonder if you can help
    Problem Solver:
  • 12 Answers
It sounds like it needs a belt kit (New drive belts needed).
If this old VCR has not been used for a long time it could also be ceased up.
Posted on Sep 13, 2008
Tip
Audio skip and lag errors on your recorded programs on an Amstrad DRX180 PVR2...
This is a great tip if you have a PVR2 Amstrad DRX180 Sky + Box if you are experiencing audio problems on some of the channels.Cartoon Network, Virgin 1 and Channel 4 are the worst effected.
It is not an LNB problem nor is it a cable or Satellite dish location problem as some may lead you to believe. The REAL problem is that there is a known fault with these boxes on this make (AMSTRAD) model only (PVR2) that doesn't appear to manifest itself on the PACE or THOMPSON Models PVR2 or PVR3.
You need to email James.Murdoch@BSkyB.com explaining your problem and presenting the following arguments (if the statements are true for you):
1. That there is mounting evidence that a whole batch of Amstrad's are suffering from this this common problem. More importantly however it was Sky themselves that supplied these units to enable their Sky+ service (for which they charge you monthly) but the units they supplied have been rendered unfit for purpose to fully enable that service.
2. That there is mounting evidence that the problem started directly as a result of Sky changing the operating software during the summer 2006.
ie. Sky caused the problem to occur in equipment they supplied, for a service they charge you monthly for.
3. That your expectations are that the unit will be replaced for freeby a brand new Sky+ PVR, as Sky have done for other customers that are in exactly the same situation. There is evidence that replacement refurbished units start to suffer from the same problem in due course and you do not want to risk that. You pay a lot of money for the Sky services so you expect to be given the best possible customer service and have your expectations met.
4. That you will have to consider canceling the whole Sky service if your expectations are not met, because with a failing unit the monthly cost does not represent value for money.
Don't forget to include you System Details in the email, the email you receive will hopefully offer a free call out, and a brand new PVR3 (although they can't guarantee the make). You may also receive a courtesy telephone call. If you only receive the call but not an email,then email back requesting details of their intentions in writing byway of a return email.
You are not owed a PVR3, nor do you have any rights to one. It just that by asking for one you are providing yourself a degree of protection against the fault continuing.
Hopefully you will get a PVR3 to solve the problem.
on Dec 02, 2009 | Audio Players & Recorders
No audio or sound coming from speakers ,I tried all speakers oulets an nada zero
Hi William,
  1. Make sure that the muting is not on.
  2. Please press "speakers" button under the power on button to ensure that the speakers settings are not turn off.
  3. You have to select the right input and make sure that the input selected are turned on and working such as DVD, VCR, TV, etc. to isolate them from fault. Used another cable as much as possible.
  4. If still no sound, the fault is inside the unit and most likely faulty sound output IC. May I know if the unit seems working fine except from the audio problem. Also, please let me know if you are handy in electronics, have a multimeter and necessary tools for troubleshooting?
Kind Regards,
Jdvillanueva
Nov 25, 2011 | Panasonic SA-HE75 Receiver
I have Sony Wega model No. KV-XA25N90 and it blinks two times. (2 times blink, paused, 2 times blink then paused)...please can you share me and idea what is the symptons.
there is some over load in the power supply.thats why it gives two blinks. may be because of power supply fault. or the horizontal out put transistor. first check the horizontal output transistor . if found faulty replace it and the power the tv. if it become short again there will be problem with LOT.
ok
Dec 21, 2010 | Televison & Video
Temperature lights stays on an oven is overheating
From the symptons described, I would say that the thermostat is faulty that controls the oven temperature, normal procedure is replace the faulty thermostat.
Nov 30, 2010 | Baumatic B904SS Stainless Steel Electric...
VHS loads and begins play - fuzzy lines immediately and screen turns blue - is this fixable? If so, what do you recommend?
Hi
Have you tried a head cleaning tape in vcr as fault might be due to dirt on video head or on the acl head, if this does not clear fault video heads could be faulty is could be costley.
regards windyhouse
Mar 29, 2010 | Sony SLV-R1000 S-VHS VCR
A 220 volt Amstrad monitor that i want to convert to use 110 volt
engagetek, This would be a very easy thing to do if and only if the label on the rear of the unit has printing similar to my GATEWAY LCD. It states as follows: "100 - 240VAC input 50/60hz." If your Amstrad unit's label reads "220-240VAC 50/60hz only, then you will need to reverse engineer the "ac to dc" power supply, be it an old "linear" or a modern "switch-mode-power-supply" type. You did not state what type of monitor technology your Amstrad is. CRT, LCD, Plasma,???? I would guess that it is a CRT type. Well anyway, I hope the info was of some use. Bye for now, I'm louie12fix on fixya
Oct 11, 2009 | Computers & Internet
Manual. need to know what the connections are for
User guide or Manual for Amstrad Sky+ ...YYY
2 posts - 2 authors - Last post: 27 Jun 2007
I need to add a second sat lead from the LNB to the Box. None the less I need a book of words that tells me about the Amstrad 180 sky+ box. ...
forums.vnunet.com/message.jspa?message... - 29k - Cached - Similar pages -
Sky Digibox remote control codes for your television
This User Manual is the ideal solution if you've bought a Sky Digibox without one. .... it ALSO operated ALL of the functions on my Amstrad Sky+ receiver (not .... in the Digital Installation Manual or via the Sky Customer Service option in ... This actually selects Sky+ mode, but a Sky+ remote works a sky HD box. ...
www.satcure.co.uk/tech/digicode.htm - 49k - Cached - Similar pages -
User manual AMSTRAD SKY PLUS - User guide AMSTRAD SKY PLUS ...
User guide AMSTRAD SKY PLUS. USING YOUR SKY+ WELCOME TO YOUR SKY+ BOX GUIDE .... to repair your Sky+ box. For repairs, please contact Sky Customer Service. ...
safemanuals.com/user-guide-instruction... - 98k - Cached - Similar pages -
For Sale : Amstrad Sky+ Box and QED 1.5m Squart Cable - AVForums.com
Due to an upgrade to Sky HD I have for sale my old Amstrad Sky+ box (model no. DRX180). ... Will try to find the manual for it as well. ...
www.avforums.com/forums/home-cinema-hi... - 102k - Cached - Similar pages -
Amstrad Sky+ Box - HELP PLEASE! - Sky+ - Digital Spy Forums
6 posts - 5 authors
Amstrad Sky+ Box - HELP PLEASE! Sky+. ... The Specifications in the manual state: Hard Drive: 160 Gb (with 80 Gb for personal use); the packaging also has ...
www.digitalspy.co.uk/forums/showthread... - 55k - Cached - Similar pages -
amstrad sky plus on standby
Following the instructions at the top of page 66 in the Manual fixed it. .... Go back and wait by your sky+ box and you should see the red recording light come on, ... Sky & DLM, Sky Broadband Service Status, SkyUser Bandwidth Meter ...
www.skyuser.co.uk/forum/sky/17069-amst... - 117k - Cached - Similar pages -
sky+ box keeps making beeping noise. - Cable Forum
15 posts - 3 authors
can anyone tell me how to stop sky+ box from making a beeping noise, ... thanks paul ill read manual & see if that helps. my sky+ is an amstrad pvr3. ...
www.cableforum.co.uk/board/64/33616556... - 87k - Cached - Similar pages -
Sky+ box amstrad dx280 - FixYa
Technical Support, Instructions & Repair Service. Home | My Expertise | Sign In ... Related Searches: sky remote, sky box, amstrad, skybox, sky manual ...
www.fixya.com/support/t1223689-sky_box... - 49k - Cached - Similar pages -
MobilePhoneMadness.com - GUIDE: Upgrading Your Sky+ Box
Amstrad Sky+: Equal in size as the Pace Sky+ V2 and looks identical, ... We hope Sky will fix the V1 firmware at a later date, as there no manual fix we can ...
www.mobilephonemadness.com/forums/arch... - 13k - Cached - Similar pages -
Amstrad DRX 180 - Review - How did we live without it???
The problem with the cable service, however, is that when you look at the ... No matter which Sky+ box you end up with, the instruction manual is the same ...
www.ciao.co.uk/Amstrad_DRX_180__Review... - 82k
May 19, 2009 | Televison & Video
I got an all in 1 universal remote & I cant find the 4 digit code
Universal remotes will not in most cases operate anything but TV sets if they are the cheap ones. The ones that operate more types of devices are mush more costly. Go to the www.remotes.com for more information.
May 03, 2017 | Televison & Video
DVD-VCR Reorder, Model DVD-V5650
Hi.
On the more modern vcrs this problem can be caused by several things, Faulty mode switch, Deck alignment incorrect, reel idler faulty.
I would advise if the machine is only 3mths old it will be still be under warantee so take it back to shop.
Chris.
Nov 26, 2007 | Televison & Video
Open Questions:
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
