Question about Dell 5650 Computer Speakers
Static in speakers even at minimal volume - Dell 5650 Computer Speakers
  • 62 Answers
Try to change the location of you desktop PC...because some static sound is came from the other device creating static...like lantern with ballast ..etc
Posted on May 26, 2010
How do i connect a set of Harmon Karden HK695-01 speakers to a Macbook Pro Mid 2010
HI Marc
Follow the steps below
Step 1:
Connect the green connector from the subwoofer into the headphone jack on the laptop, the black connector is not used, leave the rubber cap on the black connector to prevent static from the pin grounding on the system.
Step 2:
Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3:
Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4:
Plug the AC plug of the HK 965 into the wall outlet
Step 5:
Turn on the speaker set and adjust the volume accordingly.
PS: Do not Forget to adjust the Laptop volume also to minimize Distortion. Enjoy!
Jun 04, 2015 | Harmon Kardon Hk695 - 01 Audio System...
I getting static comeing through the speakers even at low volumes
90% bad connections, wiggle turn connections even bad ground on power will cause, I found swiver or turn nob volume dials go first and do this also.
Apr 09, 2015 | Audio Players & Recorders
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
On my 2003 Avalanche, after the radio has been on for a few minutes static starts in the front right speaker then travels to all of them. As the static gets louder the radio volume goes down and the static...
take out the speaker in question and test it.
a 9v battery is good enough to 'burp' it.
if it makes a scratchy noise when you put power to it then you have a short in the voice coil.
Burping a speaker is just a short power up. Don't hold power to it.
Tap it on and off like a music note measure.
Apr 16, 2017 | 2003 Chevrolet Avalanche
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
I have problems with my logitech z 2200 i have static on the speaker i unluged and even switched the plugs which ever speaker is pluged into the slot will have static i got this system as a gift plz help...
Read this here -
http://forums.logitech.com/t5/2-1-2-0-Speaker-Systems/Z-2200-Touching-the-remote-volume-knob-results-in-a-very-loud/m-p/369699;jsessionid=4ED1A1BC248CB27152E9281D845FAF4A
Hi, the crackling is mostly a result from dust and debris building up on the contacts of the volume knob over the years.
You could try taking some compressed air to the space between the knob and the pod.
and
Sometimes with the power off rotating the knobs from end to end will also help.
m/E
Sep 14, 2009 | Logitech Z-2200 Computer Speakers
Blippy Sound
Sounds like the cords that are going into the PC/system have static. Remove the cords from the speakers and simply put your finger around the jacks to remove static. Push the cords and the jacks back in and switch on the speakers. Then twist the volume control, turning it up loud and then low, then loud and low again. That should cure the problem as it removes static that gets built up over time. Either that or your speakers could well be damaged.
Mar 28, 2009 | Altec Lansing VS4121 Speaker
Bose lifestyle 20 static
if you have turned the speakers to a high volume you have to tighten all the screws and bonds that should help
Oct 14, 2007 | Bose Lifestyle 20 System
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Dell 5650 Computer Speakers Logo
311 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
