Question about Troy Bilt Tb70ss Gas Trimmer
Won't run but it starts. Replaced the spark plug, new fuel. cleaned out the lines. tokk the carb apart blew it out it looked fine.
  • 1,338 Answers
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
John Deere riding mower Model 115 won't start
fuel related if it starts and runs with a squirt
take fuel tank off and clean it out
have to re check the carby
float , needle or float level clogged jet in carby
Apr 28, 2017 | Garden
RBC30SET worked fine but having run ou of fuel now won't even turn over
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 19, 2012 | Garden
My ryobi x430 will not start. Replace spark plug and still won't start
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, 11
Feb 01, 2012 | Garden
Toro model #51932 won't idle, runs fine above idle
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ==
Jan 09, 2012 | Toro Garden
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Jun 30, 2009 | Garden
Troy Bilt Tb70ss Gas Trimmer Logo
446 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
