Question about Philips Televison & Video
My Philips Magnavox MX6071 65'' Projection television won't turn on. When I press the power button the green indicator light turns on then slowly fades out. The screen is just black and won't fully power up. Any suggestions?
SOURCE: Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Posted on Nov 16, 2007
ctf1800
  • 4402 Answers
SOURCE: TV screen problems
convergence amp IC's stk392-???
Posted on Dec 03, 2007
  • 3 Answers
SOURCE: philips magnavox tv motherboard
part warehouse out of dallas 1 800 321 6993 give model No. they have a research dept. 48Hr call back
Posted on Dec 11, 2007
  • 5 Answers
I had the same problem where all of a sudden it started bowing on top and bottom and the colors were bad. I read on here and other sites about the 2 convergance chips so I figured why not try as the tv was going to get thrown away because I could not find anyone that would touch it. Well I ordered 2 stk392-120's (I know others are saying use the 150's or 180's but I just wanted to put the same ones that were in there) I ordered them from electronix.com for 9.99 each plus 6.60 for shipping they took 3 days to get here and I installed them tonight and it worked great. The whole thing took only about 2 hours from start to finish. Here's a couple of tips....the chips are on the far left when looking at the tv from the back, make sure you mark with a marker where the wires go that you have to unplug as there are about 10 of them, each chip has 19 pins that you will have to soder make sure you have a soder ****** to get all the old soder up as you are heating them up, after you are done puting it back together leave the back cover off and turn it on, then go into your menu and go to pictureand go to manual converge and go to undo multpoint and restore factory as this will reset it all. Then if your color is still a little off as mine was there are 6 knobs in the back of the tv by the chips you were working on, find a channel with a lot of colors and try adjusting the top 3 a little at a time till you get the right color that you like. This should do it. It took 26 bucks and 2 hours for me to fix a tv I was ready to replace, thank god for the internet to be able to look stuff like this up. Good luck!
Posted on May 09, 2008
welcomejee
  • 10594 Answers
SOURCE: Picture is distorted on my Sony Grand WEGA KDP-65WS550 65 in. Rear Projection HDTV Television
Can you paste snap of distorted picture of tv here to understand what kind of distortion is this.
Thank you.
Posted on Sep 09, 2008
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
Phillips Magnavox 9p6034c 60 in. rear projection t.v.
are you sure!? or maybe you set at the pip viewer! go to settings!
Oct 01, 2007 | Philips Magnavox 9P6034C 60" Rear...
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Model # 30PW850H37A Won't turn on
Likely power supply failure. This could be on a separate board that can be removed and repaired or replaced. Look for a smaller board with larger components that look like transformers and accepts the incoming AC line.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60 in. Rear... Problem
I had a similiar problem. My screen would shrink in then expand. After a few months of doing this it just broke altogether. No sound or video.  Its not fixed.
You can get a repair kit from this site.
http:///www.magnavoxhelp.com
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
