Question about DISH Network DVR 510 DTV Receiver / 100-Hours Video Recorder
DVR 510 WON'T WORK ANYMORE
Dish dvr 510 was working fine for last month and suddenly last night the tv and box turned off and I have been unable to get the box to work. Help! I will have to share the main tv with my kids, and can only take so much of Nickelodeon and Cartoon Network. Thanks.
  • 374 Answers
Did you have a power outage last night or lightning strike? If not unplug the receiver for approxiamately 30 seconds and plug it back in to the wall plate. Try to turn it on now. If it fails to power up it may indicate that the receptacle is bad or the receiver. Swap the plug from the receiver to the known good outlet the tv plugs into and try to power it up. If it fails the receiver is dead and you will need a new one. 510 are due to be discontinued with Dish so your local provider may not have one to replace yours with and you may be left with the option of upgrading the receiver, seeing if Customer Service can send you one out if you have a warranty program or buying one from a retailer or online.
Hope this helps you.
Posted on Aug 28, 2008
SOURCE:
New customer. Installed yesterday. Worked fine last night. Turned on today, all I get is searching for signal on satellite in 2.... (771).
Go to your menu and find your signal strength bar.It's possible that your dish has shifted.The bar should read at least 60% or above.
Sep 25, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
I recorded 'Rocky' on the DVR at 4/16/10. Once I saw it on the recorded movie list, I made sure to protect it, and it was fine until today, when it just suddenly disappeared. The event list is currently...
Hi, my name is Phillip Chang and I work with DISH Network's Technical Support Team.
We are sorry to hear that Rocky was not recorded like you had wanted it to be. If this were to ever happen again unplug the receiver for 10 seconds then plug it back in.
If the issue continues after this give us a call at out 24/7 technical support number for additional steps:
1-800-333-DISH (3474)
May 04, 2010 | DISH Network DVR 510 DTV Receiver /...
DISH DVR doesn't respond to remote
  1. If this is a TV2 location take the remote to the location of the DVR.
  2. Open the door on the right side of your receiver.
  3. Press SYS INFO.
  4. Press Record multiple times on your remote.
  5. Exit the screen and see if the remote works, if not replace the batteries and repeat steps 1-4
  6. If the remote still doesnt work, and this is a tv2 location (no receiver in the room with the tv) check the antenna on the back of your receiver, make sure that it is connected tightly and standing straight up.
  7. If none of this works call Dish and ask for a new remote.
Jan 22, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Dish 510 DVR that wont record properly or play paused TV show
Make sure that the software is correct. Should be P4.07
you can go into the DVR and replace the hard drive but I would suggest getting Dish Home Plan, Replace the receiver and then cancel the Home Plan. Talk to Dish Network and they will work with you.
for tech support go to: tech.dishnetwork.com
Dec 27, 2009 | DISH Network DVR 510 DTV Receiver /...
Dvr not responding
There was a software update early this morning which caused your recvr to go to recovery mode until it downloads the new software which takes about 4 hours. Once this is done you should be just fine!
Dec 10, 2009 | DISH Network DVR-625 DTV Receiver /...
Want to copy shows recorded to DVR onto computer Howto...
ArmyMason,
Unfortunately as a Dish Network Employee I must inform you that acording to Dish that is not possible however a good computer tech may be able to help you with a work around but keep in mind that if any damage occurs to the receiver that Dish will charge you for the receiver. When you do upgrade check into the receiver models that have an expansion port for an external hard drive. A 211 which is a solo hidefinition receiver without DVR can have a port activated for as one time charge of 39.99 and you can use the hard drive you supply as the DVR. Yoiu also will not be accessed the 5.98 DVR fee every month and if the receiver needs replacing you still have your recordings. Thanks for using Fix Ya.
Apr 01, 2009 | DISH Network DVR 510 DTV Receiver /...
Dvr not recording
It sounds as if your going to need to replace the receiver as the hard drive has an error on it. I assume you can record live TV. There are also few 510's in the Dish Network service area throughout the country so my suggestion is to have Dish send the receiver to your home as opposed to creating a work order for a technician to come to your home as it will be hard to ensure you get the 510 back.If you decide to upgrade to a HD receiver try to get a model that does not have the internal hard drive but also has the expansion port on it. There is a one time fee to activate this port of 39.99. This amount will be recovered in the first year by using an external hard drive eliminating the 5.99 DVR fee every month. This option also allows you to have better control of your recordings and makes them portable. They also will not be lost by replacing the receiver. If you are a real big tv fan check out the sling box offers. Thanks for using Fix Ya.
Mar 17, 2009 | DISH Network DVR 510 DTV Receiver /...
510 DVR has to reload sat signal when accessing recorded events.
There was not a software upgrade in the last month for the 510 according to Dish Network. With that being said the issue is more than likely a bad hard drive. If you have to replace the receiver ask about a non dvr model that supports an external hard drive. This will allow you to keep from paying the dvr fee every month and allow you to have better control of your recordings eg. more record time, saved recordings if receiver needs to be replaced etc. There is a 39.99 one time fee for Dish to enable this feature but it is well worth it in my opinion. You may also want to check out the line of Sling media they have available also if you are an avid TV fan.
Feb 20, 2009 | DISH Network DVR 510 DTV Receiver /...
Have dish receiver 510, channels i need are on transponder 21, reciever changes to transponder 4 and there is nothing!!! this is on satellite 129 only, 110 and 119 work fine
Donna,
I am sorry to hear of your troubles. I am assuming you have another receiver in the house that is an HD receiver as the 510 is not and it would not make any sense for you to have the 129 orbital without it. If you go to the other receiver and are able to get transponder 21 on the 129 bird then the issue lies in either the cabling, connectors, barrels and or wall plate, or the 510 itself. Assuming you were good to go with the hi def receiver move it to the 510 location and see if you are able to still p/u the 21 transponder. If so, the 510 is bad and needs to be replaced. If not the problem lies in the aforementioned areas. if yoou are unable to get the 21 transponder on the hi def receiver also then more than likely the dish needs to be repeaked. If I can be of more assistance let me know. Thanks for using Fix Ya.
Feb 19, 2009 | DISH Network DVR 510 DTV Receiver /...
Televison & Video Logo
312 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
