Question about Ovens
Oven model PDN790S*04 We had aoverflow and have marks between the 2 layers of glass on the lower door.How can you remove the door and open the glass to clean?
  • Ovens Master
  • 19,396 Answers
Hi.
You need to pull out the door. Place the door on a big table. Take apart outer door casing and glass, then access to inner glass.
Procedure is similar to the one listed here for Kitchenaid: Replacing the inner door glass.
Here the diagrams for PDN790S:
Posted on May 26, 2010
Model fxus6how. How do I remove the door to clean between the two layers of glass?
Moira,
Unfortunately you probably will not be able to clean between the glass. Those usually come as a sealed package and are not able to be separated. You can try taking screws out around the perimeter of the door and remove the glass pack, but I doubt that you will actually be able to separate that glass pack. Sorry!
May 15, 2015 | Ovens
Tip
Range/Stove/ Oven Door Glass Replacement
I see many questions come up at Fixya.com about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 22, 2010 | Ovens
How do you clean the oven door glass inbetween the layers
door needs to be removed and disassembled first. Check My Video
May 18, 2014 | Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Outside door glass has slid down
Sounds like the door gasket/seal has pulled away from the rest of the door frame and layers. You might be able to take the door off of the hinges, and cabinet, and take apart the layers to readjust.
Dec 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I self cleaned the oven for 4 hours and it worked great. I decided to take the front glass off to clean inside it. it was quite dirty inside and the self clean did not effect it. Once I put everything...
The procedure to Disassembling the door is as follows:-- 1. Set the oven door wide open. 2. Lift the hinge jumpers with your thumb and index fingers, then turn them fully outwards to the end of stroke. 3. Turn the door towards the closure position and lay it on the jumpers: in this way the hinge's spring is blocked. By fully closing the door the hinges are unhooked from the connection slits which are integral with the oven muffle. 4) Re-assemble the door by carrying-out the aforesaid operations in the opposite order. Disassembling of the door glasses:-- for your safety, before removing the glasses you should remove the oven door. To facilitate the cleaning, after having removed the door from the oven, you can proceed with the disassembly of the glass. Release the two upper blocks so that the glass can be removed. After the cleaning you should reassemble the glass, replace the blocks and lock into position. Check that all components have been assembled correctly and than you can re-assemble the door onto the oven. check fig:-- For more help click this link directly. The model and brand is different in the picture but the procedure to assemble the door is similar to your model http://www.partselect.com/ModelFrames.aspx?ModelID=1015781&ModelNum=plef398aca&ManufactureID=4&Selected=QN7WQCV6&Position=1&mfg=Frigidaire&Type=Appliance&Mark=3 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 13, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
132 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
