Question about Haier HWR10XC3 Air Conditioner
Plug heats up, blows circuit breaker
Plug heats up - hot to touch, blows circuit breaker once reaches cooling temp of 75 degrees
  • 901 Answers
Plug is having loose contact. may be wire are loose inside socket. Tighten them. The contact should be firm not sparky loose.
Posted on May 27, 2010
1994 Chrysler Lebaron Convertible In traffic with
If the cooling system is functional, yes.
The ac condenser adds heat to the air coming thru the radiator when the ac is on. If the engine cooling system is weak, the extra heat will make the engine run hot.
Low coolant flow thru the radiator is a common cause.
Sep 01, 2013 | 1994 Chrysler LeBaron
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
1998 gmc surburban. front blows 82 degrees, rear blows 48 degrees. ambient is 91 degrees. this is with max-recirc-full tilt.the valve for the heater core does not change position no matter where i put the...
Hi John,
Your right with your diagnostics, you have a blend door problem. If your switching to cool air and it is still hot then you also have a heat exchange unit fault, this is the component that changes the water flow from hot to cool by shutting off. If it is not operating correctly this will give you constant hot air no matter where you temperature switch is positioned.
As for the warm air while the engine is cold, sounds like the blend door is still open to atmosphere tempreture and if it is hot outside will pull that hot air into the inside of the vehicle.
Have the heat exchange valve checked, and the only way the check blend door operation is to remove the wiring from the blend doors and have the circuit tested. If the circuit is ok then the blend doors will need to be replaced.
Hope this helps
Jul 24, 2011 | 1998 GMC Suburban
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
Turned heat on but only blows cold air
Any product that produce heat have a thermal breaker, a thermal fuse, or both. Thermal breaker usually look like short cylindrical shaped device, while a thermal fuse look like a fuse in which one end is pointed, and it is rated by how many degrees it will go bad. It would say it on the fuse. Thermal breakers will open the circuit when it reaches certain temperature, then closes again as the device cool down. This process keeps repeating to limit the temperature of a heating device.
Nov 27, 2009 | Intertherm P3RA-048K Air Conditioner
Can not get temp below 77
Is the thermostat set up for automatic change over from heat to cool? If so, the heat is probably set for 75, you will need to lower the heat setting in order to Lower the cooling. the stat won't let these settings with in 2 degrees of each other so the heating and cooling don't fight each other.
Aug 25, 2009 | Heating & Cooling
UNIT NOT BLOWING WARM AIR-OR REACHING DESIRED TEMP
I assume this is a heat pump. The outside unit may be icing up. It should have a defrost cycle with electronic control that sometimes fails or sensor associated with the electronic determination of when to defrost may have failed or may not be sensing because its out of position. You can check for a defrost problem. If frost is blocking the outside unit air will not pass through it after the frost builds up and you may be able to see the white frost as well. If all this is true you need to get a service manual and use its procedures to find out why the unit is not defrosting.
Jan 12, 2009 | Weather King 12AJA4801AH Air Conditioner
Heater
First you have to make sure there is colant in the radiater to heat up...if full of coolant,try replacing the thermostat....very easy and cheap try...then make sure no air in system after filing,warming up vehicle,and shutting off a few times to work air from system...if there is still no heat and truck is running at temp(Aprox 200 degree) you may have a blocked heater core,and this can be cleaned by backflushing heater core..take both small hoses off of engine and water pump and run a garded hose through it both ways....good luck..Lee
Dec 15, 2008 | 1993 Chevrolet K1500
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Haier HWR10XC3 Air Conditioner Logo
160 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
