Isymphony m1uk dab
My stereo works but it does not search for the channels on the radio the screen is on and it is stuck on one channel without any sound. Do i need a special aerial to tune it or is there something wrong with the radio itself I bought it as it is without an aerial Any help is appreciated thanks
SOURCE:
  • 579 Answers
SOURCE: tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Posted on Jan 10, 2008
SOURCE: tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Posted on Jan 18, 2008
SOURCE: Help to be able to tune in radio stations
Cannot tune into stations, display shows high triple digit numbers only.
Posted on Oct 15, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Posted on Dec 09, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
My Proscan flat screen, i can't get it to search channels automatically. it wont turn on without plugging and unplugging. Help Please!
Go to the link and ask the question there.
http://community.insigniaproducts.com/t5/Televisions/Need-help-screen-is-stuck-saying-quot-Please-Run-Channel-Auto/td-p/44406
Oct 26, 2016 | Proscan Televison & Video
How can I listen to the radio without the head set?
Hi Arthur, unfortunately you can't as the wired headset acts as an antenna!
Since the FM radio uses the provided wired stereo headset as its antenna, before opening the application, connect the headset to your phone's the audio jack.
9.3.1 Opening the FM Radio
1. On the Home screen, touch
2. The first time you open FM radio, touch Auto tuning, which automatically scans for
available FM channels, saves them as presets, and plays the first FM channel
found.
May 01, 2016 | Huawei Cell Phones
How do I preset a Bush DAB radio?
Usually select/find channel you want and press and hold the number you want the station held on. i.e. search for Heart, press and hold button number 2 for 2 seconds-it's set at number 2. repeat for other stations...
Dec 10, 2014 | Audio Players & Recorders
How do i make the screen wider or in full picture mode?
You need to be on a digital channel, standard TV will show in the middle of the screen, like letterbox. If you're using an antenna, go to channel 2.4. if you have cable, go to a higher number channel (on fios, channel 2 digital is 502)
Apr 18, 2014 | iSymphony LCD26iH56 26 in. TV
I HAVE A SC-HC30DB SYSTEM AND IT'S NOT LETTING ME IN THE DAB MENU,DAB NOT WORKING ALL WORKING OK OTHERWISE.
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
Jun 29, 2011 | Panasonic SC-HC30 Audio Shelf System
Radio c\works however i cannot change the channel. It is stuck on 1 channel only.
Do any of the switches seem to work at all? Without knowing what brand and model radio it is, it is kind of hard to say what may be wrong with it. If no switches seem to be working, you may have a bad switch.
Jun 27, 2011 | Car Audio & Video
Wont change channels...stuck on channel 8
on this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
Apr 16, 2009 | Midland 1001Z 40-Channels Base CB Radio
The buttons to turn the volume up and change the channels on my dab pure elan rv40 do not work. i can however turn the volume down and change channels down
make system microprossesor reset according to your model.
---try to make system reset by disconnection and connection.
if all above failed bring a spray lubricant contact cleaner from radio shack and apply spray in volume and channel buttons,
Aug 18, 2008 | Audio Players & Recorders
Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Jan 18, 2008 | Denon AVR-1804 Receiver
142 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
