Question about Dell E173FPb 17" TFT LCD Monitor
I turn it on and the dell logo comes up and then the screen goes blank. Already had the hard drive looked at. All is good.
  • 11,361 Answers
Try it on another PC, if it still does not work, please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
Posted on May 26, 2010
What solution because dell notebook blank display after reboot
If the Dell logo comes up on the screen and goes to blank display, the problem is in the hard drive or windows files have been corrupted, remove the hardware and reseat it back in place, sometimes this will restart it, if no change! reload your operational system with the disc if available to factory setting. If none of these work the hard drive needs to be assessed for replacement.
Mar 23, 2012 | Dell Inspiron 6000 Notebook
The pc starts and the Dell logo comes up but no windows boot
press the Fn Key and the power button see if the diags will run. You may have a hard drive problem or an issue with the operating system
Jul 09, 2010 | Dell Inspiron 1545 Notebook
The dell logo flashes then the screen goes blank. The hard drive keep flashing like the laptop is booting up okay it is a xps m140 and has vista home as a o/s
After the logo flashes, press F8, repeatedly, until a white-over-black "boot menu" is displayed. Choose "Safe Mode", to see if this "minimal" version of Windows will startup successfully.
Dec 13, 2009 | Dell Inspiron XPS M140 Notebook
I accidentally disabled the screen
try booting in safe mode and do system restore up to the last good working date of your laptop. . .
hope this helps.
Oct 27, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
My E172fp has a blank screen...when i unplug and plug it back in,the "dell dimension" or whatever that logo is comes on for a second, then the screen goes blank and stays that way.another monitor works...
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Feb 25, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Blank screen when computer is turned on
When you get the Dell splash screen press the F2 key to get into setup. Use the arrow keys to go down to Drive Configuration and press enter. Go down to Primary Master Drive and press enter. Is the Hard Drive listed there? If not, that is your problem. Press Escape then use arrows to go down to Memory Information and press Enter. Is all of your Memory listed? If not, that could be the problem. Press "esc" to get out of setup. If the Computer does not freeze while in setup I would suspect the Hard Drive is bad. Is the Pointer responding to Mouse movement or does it lock up? In your situation I would first try to Boot from the Windows CD. Write back and I can explain how to do this. If that does not work I would begin to test Hardware. Do you hear any Beeps when the unit is turned on? If you can, E-mail back with more Info.
Jan 16, 2009 | Dell Dimension 3000 PC Desktop
Laptop
sounds like an unhappy hard drive..can you try F8 when it starts to boot, before the logo hits the screen, that takes it to SAFE mode. try the last known good configuation option, if it is there. otherwise, safe mode
then do disk clean
defrag
and then restart.
Oct 19, 2008 | Dell Latitude D600 Notebook
Dell E173FPb 17" TFT LCD Monitor Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
