Question about JVC HD-61Z886 61" Rear Projection HDTV
Last night the power went out for a split second and came back on immediately. I have the JVC hd-61z886. At first the blue power button was lit and the red indicator was flashing. Then I unplugged it and let it sit for a half hour. Now I have nothing. What could this mean?
  • John Renken
    John Renken May 26, 2010
  • 10,594 Answers
If you do not see any power indication in tv that means power supply board got defective, normally power indicator lit when tv got plugged in and if that indicator is not lit that shows problem with power supply board and most probably fuse got blew off for some reason.
If you are handy with electronics stuff repair then unplug tv, take off back of tv and follow power cord that will take you near main fuse, replace it if it is blown and replug tv back in, if fuse blow off again then power supply board need to be replaced by tv tech.
Hope these info will help you.
Thanks.
Posted on May 26, 2010
  • 2 more comments
  • John Renken
    Where can I go for directions on the removal of the rear bezel? I am handy, but know that one should be well informed before attempting to tear apart electronic items.
  • Shahid Electronics
    Shahid Electronics May 26, 2010
    Lower part of back cover will be removed to access inside tv, top of rear is projection system that has mirror.
    Please confirm its JVC HD-61Z886 or any other model?
  • John Renken
    It is JVC HD-61Z886. I don't see a lower panel though.
    Correct, its lower front panel that need to be removed.
    Below image will help you how to remove it.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be an issue with the power supply board and/or a component on that board has gone bad and needs to be replaced. To start with open the back of the unit and inspect the power supply board for any bulged/swollen capacitors, also if you can test the power supply board with a multimeter. Power surge might have caused a component to go bad as from everything that you have described it seems to be a power issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • John Renken
    This happened before about a year ago and I unplugged it and it worked after that. Is there a reset mechanism?
  • Rylee Smith
    Rylee Smith May 26, 2010
    To reset
    it follow these steps:
    1. Turn off the television and
      wait for 5 minutes.
    2. After 5 minutes unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for more then 1 minute.
    4. Plug the power cord back into the electrical outlet. If the television is
    plugged into a power surge protector, remove it from there and plug it directly
    into the wall outlet.
    If the issue is not resolved then this might have happened due to
    over-voltage and as I said earlier please check the power supply unit for swollen/bulged capacitors
    and burnt wires/components on the power supply board of your TV. Also, you should try
    and turn off the TV for 8-10 hours to reset it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
I have a hd -61z866 that powers on for about 5 seconds with no sound or picture then powers off by itself.blue light does not flash durinr the process
Bad power supply. Easy fix. Had the same problem with my hitachi. It is not powering up long enough to initiate the system check, warm up so to speak. that should be pretty accurate.
Dec 11, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Unit will not turn on anymore
First reset all settings of your router to factory defaults.
You can reset it with RESET button it is in back side of router.press it for 10 seconds.
Then check led status.
Disconnectr all connection from router then reconnect then check.
Soemtimes power problem create this problem .
Change your main power supply also check after change power adapter.
check ADSL cable ethenret cable to .
If still face same issue then your router has some hardware issue.
Let me know if you need more assistanse.
Thanks.
Sep 03, 2009 | Computers & Internet
Our LT42DV8BJ JVC tv went off and wouldn't switch back on
This my be the power supply board. Capacitors will get leakey and wont let the set start up.
Jul 24, 2009 | JVC Televison & Video
JVC HD-61FN97 rear projection TV does not have any blue colors showing.
your blue componant cable is unplugged, eather on the tv, or on the cable box, 95% thats the prob, thats if you are using componant cables, those are red blue green, and red white for the audio
Jan 07, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Tv wont turn on
You need a lamp. They are very easy to install, but they are a bit pricey. 170.00 approx.
Jan 05, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Hdm ps3
Have you went into the video setup on your ps3 and changed the resolution to 1080p?
Dec 19, 2008 | JVC HD-61Z886 61" Rear Projection HDTV
JVC HD-61Z886 61" Rear Projection HDTV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
