Question about Fisher and Paykel 36 in. CE901 Electric Cooktop
How do I know if I have fully turned off the cook top?
When I finished using the cooktop I turned the knob to off and the orange light was still on and the cooktop seems like it is still on. How do I know if I have truly turned off the cook top
  • 8,197 Answers
The orange light is on to tell you the suffuse is still hot. It should go off after 15 minutes.
Posted on May 26, 2010
I just moved to a fully furnished apartment. How do I turn off the schott ceran cooktop. Both knobs are already pointing to zero but one of the lights is still on.
This cook top light may stay on until the heating element has cooled down,
This is a warning that the top is still hot to warn you so you do not get burnt.
Feb 05, 2012 | Cooktops
Cook top burner knobs all 4 not able to turn
Just to be clear, non of the 4 burner controls/knobs will turn ? You are familiar with this unit are you ?
Typically you must push down and turn to activate them.
Let me know if that is not the solution.
Good Luck :)
Oct 29, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
Flames too high Jenn-air CCG2423
Definitely cut your loses and get a cooktop with a warranty. That unit sat on the back shelf for a reason.......it didn't work properly.
Also, but a cook top that is compatible with the safety knobs they sell as child guards at places like lowes and home depot.
here is a link to show you how the child proof knobs work
http://www.associatedcontent.com/article/327577/childproof_your_stove_safety_1st_stove.html
Jun 20, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Knobs will not turn at all.....not to ignite or at all
try to remove the knods then put a drop oil in knobs to remove the dust or try to use vise grip to help u to turn then if turn return the knobs but carefully to turn the knobs if u ise visegrip or plier
May 26, 2009 | Kenmore 36 in.33392 / 33394 / 33399 Gas...
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
Dec 11, 2008 | Dacor Preference SGM466 Gas Cooktop
Why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Nov 30, 2008 | Cooktops
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Hot Surface Light stays on
Our success has been to heat the elements to hot for about 5 minutes. Then let cool to reset temp sensor.
Can cause the problem by turning a burner on for a short period of time
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Fisher and Paykel 36 in. CE901 Electric Cooktop Logo
2,149 people viewed this question
Top Fisher and Paykel Cooktops Experts
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
