Question about Yamaha RX-V463 Receiver
Connect an ORLA SE41 to Yamaha Receiver
I am trying to connect an ORLA SE41 to my Yamaha receiver RXV563. Where do I plug it in ? thanks
Connection of a subwoofer to yamaha rx v480 receiver
Get an output from the receiver pass it through a crossover and you will get a low frequency signal , plug in into the sub..there you go.
Feb 09, 2014 | Yamaha Audio Players & Recorders
I have a yamaha nx sw150 subwoofer that i want to connect to a pioneer receiver vsx 1020 that has no system connector that the original yamaha receiver had,is it possible to connect the subwwofer to this...
Parts from all-in-one packages like this aren't inended to be pieced out to other applications. Proprietary connections are a huge clue and disincentive.
http://www2.yamaha.co.jp/manual/pdf/av/english/sys/NX-P150_e.pdf
A look at other Fixya queries gives this answer:
http://www.fixya.com/support/t4959365-yamaha_sub_woofer_model_nx_sw150
"I have this sub. The system connector jack needs a 12V DC signal to turn on. If you don't have a suitable Yamaha receiver with this connection, use any 12 V DC adapter with a 1/8 in mono plug (the tip should be positive)."
I imagine the subwoofer could be opened up and whatever circuitry is enabled by the Control signal could simply be jumpered "true" so it is always ON. That would mean the amp would be drawing power at all times, though.
Jul 31, 2011 | Yamaha Audio Players & Recorders
I am trying to figure out how to connect my ipod to my Yamaha htr-5930. Can I do that through the headphone jack, or through the aux jack? Is there anyway I can do this? Thanks! nickrd83@gmail.com is where...
Use a 3.5 mm to 2Male RCA cable. Plug this into an AUX or CD input in the back. Adjust the volume on the iPod as well as the master volume to balance out the sound. The headphone on the receiver is output only.
Apr 12, 2011 | Yamaha HTR-5930 Receiver
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I JUST REPLACED MY OLD RECEIVER WITH A YAMAHA AND DON'T SEE WHERE TO CONNECT THE POWER FOR THE CD AND TAPE PLAYER. DO I PLUG THEM INTO A POWER STRIP?
Yes, that will be fine just make sure its the same AC power as the new Yamaha is using.
Before connecting any AC mains always turn off your Amp, and don't turn back on again until all the signal cables for the new equipment are connected.
When checking if it all works, always start with low volume to check everything is correct.
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | Yamaha RX-V663 Receiver
Connect a monitor to a yahama HTR 5660 receiver
"trying to connect multiple devices to a yamaha receiver if I am using an S video to connect the tv (monitor) to the receiver do I plug it into the monitor OUT s video or would it be Input not output?" Input on the Monitor from Video Out on the Yamaha.
"if I am only using the monitor for video and not sound do I still need to plug in the audio cords or do i leave them out " - Presumably the monitor doesn't have speakers or audio connections, so it's a non-issue. Your video sources should have audio routed to the receiver. If the monitor has speakers I would also send 2-channel analog audio to it from, say, the cable/satellite box, so you could hear the weather or other lo-fi video without turning on the Yamaha.
Mar 30, 2010 | Yamaha HTR-5660 Receiver
Yamaha HTR-5760 goes to standby 2 seconds after power on
Maybe your device got the audio amplifier IC damaged
Jul 02, 2009 | Yamaha HTR-5760 Receiver
WANT TO PLUG IN A TRUN TABLE
Try using the AUX but you mightr have to buy a Phono pre amp first , then you connect the turntable to the pre amp and the pre amp to the AUX plug
May 23, 2009 | Yamaha HTR-5830 Receiver
Yamaha RX-V463 Receiver Logo
279 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
