Whilrlpool washer error F09 - Washing Machines
I had the same problem, machine would start and sray water for 2 seconds or so then would stop and display the f09 code. Worked out the the flood switch that was located under the machine in the center was faulty and sending the signal saying that the machine was over filling. So i disconnected the plug and it works a treat. So i might just order a new flood switch for safety precaution.
Hope that helped
Posted on Apr 02, 2009
  • 23 Answers
Check the drain hose and make sure it is not plugged or inked. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) Check/Clean Drain Pump Filter of foreign objects Check for Drain Pump Failure Check the Inlet Valve for proper shut off Check the Pressure switch for proper operation
Posted on Apr 07, 2008
  • Doug Hubbard
    Doug Hubbard Apr 07, 2008
    i would check the drain pump filter first it is easy to get to front lower panel take that off pump is right in front unscrew cap and clean/check filter in pump. god luck...
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
ERROR CODE F09
A typical HE3 Kenmore Elite washer the F09 code indicates and overflow has been sensed. This can be because of suds or a failure of the pump or pressure switch.
Suds is a common problem with the newer 2X-3X super concentrated detergents.
A pump that is partially blocked might cause this error
Oct 06, 2014 | Washing Machines
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
HE3t Washer Problem -
Clean out the drain pump, if this doesn't resolve it then replace the drain pump,this will resolve you issue.f09 means slow drain or no drain.
Oct 30, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Is showing a flashing f09
Hello Sir, If the Washer is turning on itself then it is a CU Problem. It must be tripped or not functioning properly.
And about the F09 error. This error comes when the washer has a water overflow. This can be removed by tilting the Machine forward by making a point opened so that the excess water flows out. This overflow is caused when the water is blocked by any other object. This overflow is surely corroding the CU and making the machine to turn on by itself.
Kindly call a technician from Whirlpool to get the internal parts checked.
Thank you Sir, Have a nice day.
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I get an F09 error and when I push the pause button the washer says there is 22 minutes left.  I can push start and the machine will start washing again.  Sometimes it will finish washing and other times I...
"F09" is an Overflow Condition error. The following link explains:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
The first thing to try is to unplug the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In some cases this is all that it takes to correct momentary glitches with the unit. If the error code reappears, follow the guidance I provided you.
This is one of those challenging errors to identify sometimes. Start with the easy possibilities, first. In addition, your washer should have a tech sheet inside to assist in component identification and troubleshooting. You can access the tech sheet by removing the lower panel under the door. If the its not taped to the back of the lower panel, it will be located along the interior wall of the cabinet.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
F09 error code for whirlpool Model GHW9250MT
Please click on the following link for an explanation of the "F09" error code:
Read through the information thoroughly and let me know if you have any questions, or require further assistance. I hope this helps you.
Jul 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
What does a F09 error mean?
Since Sears doesn't manufacture its own equipment I need a product code number to access the specific features of your appliance. Email me with that info and I can find what the error codes are.
Sep 09, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
865 people viewed this question
Top Washing Machines Experts
