Question about Whirlpool GR2SHKXKS Top Freezer Refrigerator
My freezer is working well, but the fridge doesn't
My freezer is nearly empty and working well, but the fridge section is not producing enough cold air
  • Whirlpool Master
  • 1,606 Answers
I would need to know if you hear the fan in the freezer and do you see any frost on the rear wall of the freezer ( indicates a defrost problem ) . Both will cut down or stop the air flow to the refrig section .
Posted on May 26, 2010
  • Whirlpool Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratormy freezer is working well, but the fridge doesn't - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Oct 27, 2007 | GE GSS20IEM Side by Side Refrigerator
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
The freezer part is working good but the cooler side cools but not enough
the damper vent door between the freezer and fridge section isnt opening up to let cold air in from the freezer side to cool the fridge side,its behind a plastic grille near the top between the 2 compartments,there is also an evaporator fan near this and it also needs to be operating to move the cool air
May 24, 2011 | Jenn-Air JSD2789GES Side by Side...
Freezer is not getting cold not sure if it is stuck in defrost mode
Freezer not getting cold, then defrost problem is rare, it can be compressor issue.If freezer getting cold but fridge not getting cold, then yes it can be defrost problem. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.---------- But in your problem, you mentioned, in that freezer section is not stating cooling.So the compressor can be the issue.But still try reset procedure and see, if that is helping. Try manual defrost reset procedure: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If still the same problem, then the compressor has to be inspected.
you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Apr 25, 2011 | Refrigerators
Fridge/freezer not working but light is on,located in garage,which iss v cold
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 10, 2010 | Refrigerators
Zanussi integrated fridge freezer, top half fridge not working
It appears you need to get the cold distributed from the freezer section to the frig section. This can only be accomplished by a fan that forces the cold air throught openings between both sections. Since the freezer in at the bottom, cold air cannot go upward, thereforethe fan. Chech that the interior fan (in the freezer section) is running. Check that the air openings between the sections are not blocked. Finally, if all looks good, then maybe the compressor system is slowly failing and only making enough cold for the freezer, but not enough to be circulated. Goodluck, Macgivor
Jan 02, 2010 | Refrigerators
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
Whirlpool GR2SHKXKS Top Freezer Refrigerator Logo
156 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
