Rylee just advised me that I had a convergence problem with my Panasonic PT-47WXC43 which could cost 300-350 to repair. The TV is approximately 7 years old and I'm aware there are a lot of bulbs and other things that could go out. With the age of the TV would I be better off to purchase a compatible LCD for around 700 - 800 dollars?
  • 10,594 Answers
I replied your previous question, click HERE to read it again.
If tv shows bright picture in proper focus then it would last few more years as it is rear projection tv that has 3 picture tubes (red-green-blue) to project color picture on front screen.
Its your choice to have new tv instead of repairing this one and yes, its correct that 32 inch tv is available under 700-800 dollars.
Hope these info will help you.
Thanks.
Posted on May 26, 2010
My tv looks like its stuck in 3D mode or something how can that be fixed
You will need to replace both STK392-110 Convergence ICs and also check and possibly replace the low ohm resistors. You can get the PT53WX53 convergence repair kit which covers your model. The kit contains the ICs , resistors and the CD with repair instructions. The kits available from www.tvrepairworld.com
Jul 22, 2011 | Panasonic PT-47WXC43 47" Rear Projection...
PICTURE IS BOWING INWARD AND THE COLOR . LIKE PERSON FACE IT WILL HAVE A SHADOW OF RED, BLUE, GREEN, YELLOW
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
Sep 14, 2010 | RCA HD52W58 52" TV
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Let me know if you have additional question.
Thanks.
May 25, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Please, can anyone tell me which STK39x-xxx convergence ic's are used in a Panasonic, rear projection TV, model PT-47WXC43
Your STK numbers are on the ones in your TV Big black ICs STK if they are 110s,120s,150s Use the 180s instead.better ICs For EXample STK392-110 ect.....
Feb 20, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence chips 110 installed but unsuccessful
check the resisters or send the board in to ptscorp.com
if you find bad resisters chances are you blew the ic too
Feb 26, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Another question
you can pull the plugs inside tv to convergence yoaks if tv starts up . you will need convergence ic,s
Apr 13, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
