Question about Whirlpool Duet GHW9150P Front Load Washer
Halfway through the cycle, the machine stops and a code F21 comes up. What does this mean? What needs to be done?
  • 5,081 Answers
F21 Long drain Possible cause: Clogged filter, clogged/failed pump.
1) Removing the front panel just under the washer door can be tricky, it is secured underneath by 3 1/4" hex screws, you may need a special hex driver or ratchet to remove (can get at home Depot for $4)
2) Make sure you check the tubing from the drum and out to the drain they can be clogged to
3) Twist open drain filter slowly, water will come out so put a heavy duty garbage bag underneath to catch water
4) When replacing filter make sure to line up notch at the top of filter with the groove inside and then slowly screw clockwise back in until tight
5)Make sure to replace front cover tightly, there is a drip fuse that won't let the washer run unless front cover is back on.
Socks are the most common thing you can found.
http://www.youtube.com/watch?v=qQTvBSnEWsI
Check the above video it can be helpful.
Posted on May 26, 2010
My machine keeps stopping mid cycle with an f11 error code, what does this mean?
The troubleshooting section of my manual gives a Generic fix for F codes other than F20,F21,F22 as "Select stop twice to cancel the cycle.Select DRAIN & SPIN if there is excess water in the washer. Re-select cycle and press START If problem remains, call for service."
Not much help! Try checking the inflow by removing the hose to see if there is any debris in the inlet (rust etc.) Also could be a balance issue. Rearrange load and restart the cycle.
Or it could also be a leveling issue. Use a level to see if it needs to be raised or lowered by turning one or more of the "feet" with a crescent wrench to level the unit.
Jun 27, 2014 | Kenmore HE3T Washer
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer wfw8300sw02 code F21 what does that mean
the F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
c...
Feb 03, 2011 | Whirlpool Washing Machines
My washer stopped and was flashing F21 (drainage issue) so I called a plumber. He checked the hoses and removed the panel and cleaned the drain trap. It didn't fix the problem it's still won't drain. It...
The SUD message relates to overdose of detergent detected during the Wash Cycle.
This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked. this seems to be the reason as to why your unit is not fixed even after trying to solve F21......
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Good luck
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 11, 2009 | Kenmore Elite HE5t Washer
On whirlpool duet ,am getting fault code f21 in wash cycle.
Foreign objects in the prepump
remove access panel in front remove round plastic plug clear objects have towels ready
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
174 people viewed this question
Dan Webster
Dan Webster
Sal De
