Question about Sony KP-51HW40 51" Rear Projection Television
Out of focus
The red lense is out of alignment. How do I manually align?
  • Sony Master
  • 8,457 Answers
Ur tv have a problems known as Convergence,it dead.The convergence board the 2 STk convergence ICS and some or all it resistors are dead.These parts must be change to solved covergence problems.The shop will cost u $300-350 for parts and labors.
Posted on May 26, 2010
How do I use my old manual lense with a K200D?
Move the automatic/manual focus switch (on the lower right of the lens mount as you look into the lens) to manual. Focus manually by turning the focus adjustment on the lens itself - align the split image as you would with your old camera and take the picture.
(Use a handheld light meter and set the f/stop and shutter speed appropriately - the K200D doesn't have a visible meter. I would recommend bracketing your exposures -up a stop and down a stop from the 'appropriate' stop.)
Aug 11, 2013 | Pentax K200D Digital Camera with 18-55mm...
How do i set up eye pieces and focus lenses?? Instruction manual came in chinese with no translation and we are begiiners!
During the day:
1. Point to a far (1000 meters or more) object
2. Insert the lowest power (highest number) eyepiece e.g. 25mm
3. focus on the object.
4. Align finder to match what you see in the scope.
At night.
1. Put scope out and let it reach the temperature of the outside.
2. Point finder to the moon (1st object you should always use to check scope and finder alignment)
3. Use the same low power eyepiece.
4. If everything seems fine, switch to a higher power eyepiece and enjoy the view. You may have to slightly adjust the finder to align with the main scope.
If the views are blurry, the telescope may be out of collimation. Look on the internet for generic collimation instructions.
If this still did not help. Throw the scope out! Its probably a piece of junk and will only discourage you.
Dec 12, 2012 | Optics
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
Auto focus doesn't work
http://www.retrevo.com/support/Hitachi-51F510-TVs-manual/id/371ci865/t/2/
http://www.scribd.com/doc/3401783/Hitachi-Service-Manual-TV-Plasma-42HDT5055-Chasis-PT3G
Above is your service manual, and above that is a user manual. This will assist you no end, this is the manual engineers use to troubleshoot and repair.
May 12, 2010 | Hitachi 51F510 51" Rear Projection...
Start Align with NexStar 4SE
Did you enter the correct TIME, DATE, and LOCATION? and yes you may have aligned on to the wrong stars -- they need to be "near" the center.
Feb 04, 2009 | Celestron NexStar 4 SE Telescope
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
Nov 25, 2008 | Philips 50P8341 50" Rear Projection...
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
I have a Canon 20D camera that I use with two lenses. The lens that I have most of my problems with is the 28-70 f2.8 red ring lens. When focusing It always seems to focus on what is behind the subject. No...
This is quite a well known problem called 'back focusing' there is little that can really be done about it, except if the camera is under warrnty you can send it in and they will do some laser alignment that fixes the problem, it would be worth a call to canon and getting a price quote on a service. Also it seems to be worse with some particuar lenses,
Cheers
Emmanuel
Sep 12, 2008 | Canon Cameras
Afficio 450 camera lense alignment
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Aug 19, 2008 | Office Equipment & Supplies
Sony KP-51HW40 51" Rear Projection Television Logo
88 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
