Question about Sony VAIO VGN-FJ270/B Notebook
When i click on any icon, cpu doesnt follow through with the double click command
  • 553 Answers
There's several possibilities as to why this is happening.
The first is that you may be moving the mouse some as you are clicking, when this happens windows registers this as two single clicks. Depending on what mouse and drivers it will be different. Go into "Control Panel" then select "Mouse", find the setting for "Double Click" (most likely under buttons, maybe another button of some sort to access this feature). Once you have it up depending on make and model you'll be able to adjust the settings for "Double Click". Make adjustment and test them in the "test area" until you have what you need.
Second, if you have a 3 button mouse set the center button to "Double Click" and use it to avoid this problem.
Third, Windows may be causing the problem by doing maintenance task in the background. This is usually caused by Windows adjusting your Virtual Memory. To fix this go into "Control Panel", choose "System", goto the "Advanced Tab", choose "Settings", goto this "Advanced Tab", under "Virtual Memory", choose "Change". Once there choose "Custom Size" then set "Initial" and "Maximum" to the same size, this size should be 4 time your RAM plus 12MB or the the current Max whichever is larger. Select This will stop windows from constantly adjusting your Virtual Memory, which is what makes Windows not respond to your double clicks. If you need further help respond to this solution and Fixya.com will notify me and I'll try to help you further.
Posted on May 26, 2010
Icons are missing from computer screen
A.
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
B. To re-create the Show desktop icon yourself, follow these steps:
  1. Click Start, click Run, type notepad in the Open box, and then click OK.
  2. Carefully copy and then paste the following text into the Notepad window:[Shell]
    Command=2
    IconFile=explorer.exe,3
    [Taskbar]
    Command=ToggleDesktop
  3. On the File menu, click Save As, and then save the file to your desktop as "Show desktop.scf". TheShow desktop icon is created on your desktop.
  4. Click and then drag the Show desktop icon to your Quick Launch toolbar.
Feb 05, 2012 | Microsoft Windows XP Home Edition
Tip
Create Desktop Shutdown/Lock/Restart/Hibernate Shortcut Icons In Vista
1. Right click an empty area of your Desktop
2. Select New>> Shortcut
3. In the text box titled: "Type the location of the item:" Enter the Command for the particular shortcut you would like to create. I've listed all of the commands below that activate their respective shortcut:
Hibernate rundll32.exe PowrProf.dll,SetSuspendState
Lock Rundll32.exe User32.dll,LockWorkStation
Restart Shutdown.exe -r -t 00
Shutdown Shutdown.exe -s -t 00
Sleep rundll32.exe powrprof.dll,SetSuspendState Sleep
4. Once you've entered the command, click "Next"
5. Vista will now ask you what you would like to name your shortcut. I've always just given it the name of its function (EG: Shutdown or Shutdown System).
6. Once you have named you shortcut, click "Finish". Your new shortcut will now reside on your Desktop. Simply double click the icon to activate the command.
Note: If you do not like the look of the "default" icon that Vista has given it, you can change the icon to a different one. Here's how:
1. Right click the shortcut icon
2. Select Properties
3. The shortcut properties window will now be displayed. Click the "Change Icon" button.
4. The "Change Icon" window will now appear. Here, you can select from the many available system icons. Click the icon that you would like to use as your shortcut icon and then click OK.
Your Desktop shortcut icon will now revert to the selected system icon.
That's it! Have fun!
on Oct 08, 2010 | Computers & Internet
Tip
Viewing Your IP Address Information
There are several ways you can determine your IP address information:
IPCONFIG
  1. Start / Run / cmd
  2. IPCONFIG /ALL
This opens a command window. One advantage is that you can send the information to a text file (IPCONFIG /ALL > c:\ip.txt)
But sometimes the window shows show much information you need to scroll around to fine it.
VIEW STATUS
  1. Control Panel / Network Connections / Double click the icons for your network (If the network has an icon in the system tray you can also just double click on that icon)
  2. Click on the Support tab
  3. Click on the Details button
on Sep 20, 2010 | Computers & Internet
I want to install my printer hp deskjet d2360
For solving your problem do the following:
1. Connect the Printer Properly
2. Connect the Printer Port to the CPU Printer Port / USB
3. Switch on the Printer and wait for some time
4. Place the Printer Drivers Software CD in the DVD/CD Drive
5. Select the Appropriate OS drivers and double click on the folder
6. Double click on the Setup Icon and follow the steps
7. After installing the drivers, restart the system and you can take the print out using your printer
Let me know! that i Fixya the Problem
Thanking you,
B.Krishnamacharyulu
Nov 09, 2010 | HP Deskjet D2360 InkJet Printer
My yahoo messenger doesnt update me on who is online or offline? help me please thanks...
clear your Yahoo! Messenger cache files
For XP:
1. Exit Yahoo! Messenger by right-clicking the tray icon and selecting "Exit."
2. On your keyboard, press "Windows Logo+R" to open the "Run" command.
3. Type in "cmd" and click "OK." This opens a Command Prompt window.
4. Copy and paste each of the following commands into the command prompt. Press the "Enter" key after pasting each command.
%SystemDrive%
cd "\"
rd "%ProgramFiles%\Yahoo!\Messenger\Cache\" /s /q
rd "%UserProfile%\Local Settings\Application Data\Yahoo\" /s /q
rd "%AllUsersProfile%\Application Data\Yahoo!\" /s /q
reg delete HKLM\SOFTWARE\Yahoo /f
reg delete HKCU\Software\Yahoo /f
del "%ProgramFiles%\Yahoo!\Messenger\*--*" /f /s /q
del "%ProgramFiles%\Yahoo!\Messenger\*.tmp" /f /s /q
del "%temp%\*.*" /f /s /q
For vista:
%SystemDrive%
cd "\"
rd "%LocalAppData%\Yahoo\" /s /q
rd "%ProgramData%\Yahoo!\" /s /q
Oct 01, 2009 | Yahoo Messenger
How do I find out what my CPU usage is on my MAC laptop
hi dv4242
Here is how to do it :
  1. First open the Activity Monitor
  2. Right Click (or click and hold, or CTRL click) on the Activity Monitor icon in the dock and select ‘Keep in Dock’ (if it’s not already there)
  3. Right click on the Activity Monitor icon again and select the ‘dock icons’ menu
  4. From the ‘dock icons’ menu select the ‘Show CPU Usage’ item
  5. There you have it, a nice little visual representation of your CPU usage, it is even separated by cores (if applicable)
Hope that helps
Have a nice weekend
Please rate my answer
Sep 25, 2009 | Apple Mac OS X 10.4 Tiger for Mac
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Printer Icon isnt on the desktop and doesnt show in the programs
You need to update the printer application driver, please follow the steps given below:
1. Insert the Lexmark CD and close the installation window.
2. Go to "Start" and "My Computer."
3. Double click on the CD-ROM drive letter (for example, D:Lexmark 3400).
4. Double click on the "Applications" folder to open it.
5. Double-click on the "Setup" icon to update the drivers completely."
6. Please wait for few minutes and then try to open the applications again.
Apr 11, 2009 | Lexmark X3480 All-In-One Printer
Quickcam
Error 2711
When receiving the 2711 error during Logitech QuickCam/Image Studio software installation, please perform the following steps:
  1. Use Add/Remove programs in the Control Panel to uninstall any current installation of QuickCam/ImageStudio software. For Microsoft Windows 95, 98, ME or NT
    1. Click Start, Settings, then Control Panel.
    2. Double click the icon labeled Add/Remove Programs.
    3. Highlight the desired program in the list provided (QuickCam or ImageStudio).
    4. Click Add/Remove Programs located in the bottom right of the list provided.
    For Microsoft Windows 2000 or XP
    1. Click Start. followed by Control Panel.
    4. Click the button labeled Remove located in the bottom right of the program selected.
  2. Navigate to C:\Program Files\Logitech.
    1. Double click the icon on the desktop labeled My Computer.
    2. Double click the icon labeled C:\(computer name).
    3. Double click the yellow folder labeled Program Files.
    4. Double click the yellow folder labeled Logitech.
  3. Delete any folders for QuickCam/ImageStudio.
    1. Select the yellow folder with the QuickCam or ImageStudio names.
    2. Click the menu options for File, followed by Delete.
    3. Repeat for any other QuickCam/ImageStudio folders.
  4. Delete all files located in the Windows temporary directory C:\Windows\Temp or C:\WinNT\Temp
    3. Double click the yellow folder labeled Windows or WinNT.
    4. Double click the yellow folder labeled Temp.
    5. On the menu across the top of the window, click Edit followed by Select All.
    6. On the menu across the top of the window, click File followed by Delete.
    7. Click OK.
  5. Reinstall QuickCam/ImageStudio
    1. Remove and reinsert the QuickCam/ImageStudio CD and follow the prompts OR
    2. Double click on the downloaded ImagStudio file.
Dec 27, 2007 | Logitech QuickCam Express Web Camera
Not printing
pls reomve all the print job from print spooler like just double click on the printer icon it will shows the list of pending job pls clear all the documents and restsrt the sytem and then give the print command it will work.
Oct 09, 2007 | HP DeskJet F380 All-In-One Printer
Sony VAIO VGN-FJ270/B Notebook Logo
56 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
