Question about Kenmore 700 6972 Dryer
Dryer stopped running...there is power but dryer stopped it feels very warm to the touch
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryerdryer stopped running...there is power but dryer - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_tdryer stopped running...there is power but dryer - 2_bing.gif
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 26, 2010
Fisher & Paykel dryer keeps stopping.
The overheat sensor may be defective. This causes the dryer to stop.
Oct 19, 2017 | Fisher Dryers
Whirlpool duet sport dryer stopped running after 20 minutes into a 40 minute cycle on hot.
Check for clogged vent. Vents will clog midway and if vented to the outside of a house, there is a plastic cover that usually gets covered with lint that gets wet and dries to a hard mask.
Feb 02, 2017 | Whirlpool Dryers
No heat
As I am not too familiar with gas dryers-here is a question-does the dryer normally have ignition only until the main flame is lit and a sensor warmed up that then shuts off the ignition.This is a energy saving feature that replaced having a pilot light run all the time.It should say in your manual if you have a standing pilot light or an ignitor which shoould I believe only run long enough for something like a thermocouple warms up to tell the ignitor to stop and the main flame will keep running until the cycle is complete. Hope this gives you a start and feel free to ask for more info. I'll do what I can.
Dec 20, 2011 | Maytag Dryers
Air conditioner blows air but not cooling. Cleaned filters on indoor unit, still no cold air.
Take the cover off the air conditioner and check if you are getting power to the compressor with a volt meter. Also when the air conditioner is running if the compressor is running it would feel warm to the touch and you would feel a vibration when you touch it.
Mar 22, 2011 | Heating & Cooling
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
The dryer is turned off and the door is open and there is still heat. I have to uplug the dryer in order for the heat to stop. We noticed this one morning, walking into our laundry room. (This was on...
I assume it is an electric dryer with 240 volt plug ? My guess is that it is the contacts in the motor start/relay switch that have welded themselves together and when the motor stops, the heat does not. This switch is located on the motor and it only allows the heat element to operate if the motor is running and creating the air flow. It is worth replacing. Goodluck, Macgivor
Jan 31, 2010 | Dryers
Dryer is taking way longer to dry than normal
Does it feel warm to the touch? (you did not make mention of that) If not then it more than likely is not heating at all and there could be a number of reasons why it does not heat.
1. Open heating element
2. Open thermostat
3. Defectrive motor switch
4. Damaged wiring
5. Defective heat control switch
6. Defective timer.
7. One of the 2 power circuit breakers is partially tripped. (turn them off and back on again to reset them)
If it is warm to the touch then check around the lint filter for lint buildup. Also go outside and check the dryer vent flapper where it exits your home for obstructions. Aditionaally check the vent tubing itself for kinks or obstructions. You may have to remove the vent hose from the dryer to check the tubing.
Jan 03, 2010 | GE DVLR223 Dryers
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 700 6972 Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
