I need to open ports for my xbox 360. how do you do ''Port forwarding''
    Guru:
  • 523 Answers
Hi Friends,
Please follow the default steps for all the belkin wireless routers to open or Forward ports for XBOX 360,PS3,Wii,etc
Before,Preceeding for the steps,please call to the Particular vendor and get the port numbers to be opened and please make a note of it.Also get the ip address of your particular device.
Step 1:Connect the Modem to Router (in the Port named Modem) and take another ethernet cable abd connect one end to the Router(in the port named Wired) and other end to any one of your computer
Step 2:Open an internet explorer and type 192.168.2.1 and click on Enter button in the keyboard
Step 3:Now you will be able to see the belkin router setup page
Step 4:On your left hand side click on Virtual Servers.It will ask for login password,leave it blank and click on Submit
Step 5: Put a Tick mark in the 1st check box
Step 6: In the descrption type it as XBOX360 or Wii or PS3
Step 7: In the Inbound Port type the 1st port number given by the vendor
Step 8: In the Type select it as either TCP or UDP (it will be given by your Vendor)
Step 9: In the IP Address place type the IP Address of your device (get it from your vendor)
Step 10: In the Outbound Port type the same as you have typed in the Inbound port
Step 11: Follow the same steps for all the port numbers to be opened.After completing all the port numbers click on Apply changes
Step 12: After completing this,On your left hand side please click on DMZ
Step 13: Put a Tick Mark in the Check box and type the same ip address given by your vendor for the deivce and click on Apply changes
Step 14: After completing this,go to the device and check whether you are able to access the device in the internet
Regards,
Aysaam
Posted on Jun 09, 2010
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
My xbox 360 is saying i have a srict nat type how do i get it to open?
You may want to turn on port forwarding for your xbox (This article explains how to do it....keep in mind, the settings are different for different routers: http://www.pctechbytes.com/gaming/xbox-360-port-forwarding
If port forwarding does not work you may want to add your xbox IP address to a DMZ in your router (again the settings are different for every router, but your router's manual should have how to do it)
Good Luck.
Mar 09, 2011 | Computers & Internet
Need to know how to change the nat setting off of strick on my virginmobile mifi2200 to play xbox 360
You need to go into the port forwarding section in your administrator settings, you should be able to access that by going to 192.168.1.1 and finding the port forwarding section, you then must forward the ports that the Xbox 360 requires to go online;
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 80 (TCP)
Mar 04, 2011 | Video Game Consoles & Games
Im trying to connect to live and I connected to the internet but not xbox live
Xbox live requires some ports to be open on your router. Make sure the following ports are forwarded through your internet router to the IP address of the Xbox.
On Xbox's site below they have some instructions for the most common router manufacturers.
From the Xbox website: http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/kb/xbox-kb.aspx?kbid=908874
  • Port 88 (UDP)
  • Port 80 (TCP)
Note If you cannot chat with someone using Video Kinect, you might need to open port 1863 (UDP and TCP).
Mar 03, 2011 | Computers & Internet
My network configuration has a strict NAT setting this is likely to cause connectivity problems with other payers how do i address this issue
You need to look into port forwarding. You will need to go into your router/modem's configuration and open a port for the xbox. Do some research into port forwarding.
Feb 21, 2011 | Microsoft Xbox 360 Console
Xbox 360 nat type is strict, how do you fix it
In your Router's administrator configuration, find the UPnP setting and make sure it is enabled.
If this does not fix it, you will need to open ports in your router. You'll need to open the following ports and forward them to your Xbox's IP Address:
  • Port 88 (UDP)
  • Port 80 (TCP)
Jan 24, 2011 | Microsoft Xbox 360 Console
My ports are not open and my internet say you nat type is moderate
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Jul 01, 2010 | Microsoft Xbox 360 Elite Console
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
Xbox live test fails and so does update
you need to open the port that the update is trying to go through. the easiest way is to turn your firewall off, but this opens up your security. another way is to forward the correct port through port forwarding on your router. findout which port xbox live uses and put in the information to the router
Jan 06, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Cannot sign up for xbox live
have you tried running the troubleshooter (if so, wat did it say?)
Apr 13, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
