Question about Apple iPod touch
How do i unlock my 16 gb ipod touch? 4 digit code lost
How do i unlock my ipod 4 digit code lost and i dont have the original
computer it was synced to?
  • Apple Master
  • 7,482 Answers
According to Apple, if you have forgotten the code, you can unlock the
IPod by doing the following:
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater.
Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back
to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of
your important data.
2. Connect your iPod to the computer that you want to be the primary
computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if
you forget your combination. If you can't unlock your iPod and you don't
have access to the primary computer, your only option is to restore the
IPod, which will erase all music and data."
Good Luck, I hope this helps
Please do not forget to rate me...Thank You
Posted on May 26, 2010
Got locked out i pod touch
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
Dec 05, 2011 | Apple iPod nano
Forgot unlock code
  1. Step 1
  2. Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
  3. Step 2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
  4. Step 3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
  5. Step 4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
  6. Step 5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
  7. Step 6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Feb 18, 2011 | Apple iPod touch
I have an 8 gb ipod touch that is now disabled because I can't remember the 4 digit code. The message on the ipod's screen says 'ipod is disabled. Connect to itunes.' The computer that I originally used...
connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
this process is all on the computer.
May 20, 2010 | Apple iPod touch
Ipod touch is locked forgot password cant unlock
plug it into your computer and through itunes on your original computer you will be able to reset it. If it is not the original computer that you are using you will be able to reset it but will probably lose the information on it.
May 05, 2010 | Apple iPod touch
I accidentally got a password lock and cant remember it.
Use the computer that you originally used, and open up itunes this should allow you to reset the password and resync your data. If you use a computer that was not used to sync it you will be able to unlock it but the ipod will be wiped.
Hope this helps
Oct 12, 2009 | Apple iPod touch Second Gen (8 GB,...
Visual land v-touch keypad locked
  1. Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
  2. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
  3. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
  4. When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
  5. After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
  6. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Sep 25, 2009 | Apple iPod touch Second Gen (8 GB,...
Ipod 16 gb
Step 1 Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
  • Step 2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
  • Step 3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
  • Step 4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
  • Step 5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
  • Step 6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
  • Sep 24, 2009 | Apple iPod touch
    I HAVENT LISTENED TO MY IPOD TOUCH FOR A WHILE AND I DONT SEEM TO REMEMBER MY UNLOCK CODE IS THERE ANY THAT I CAN USE SO I CAN LISTEN TO IT AGAIN
  • Sep 22, 2009 | Apple iPod touch
    8GB iPod Touch Disabled
    you will have to restore your ipod to factory default settings in itunes.
    or you can jailbreak the ipod with software like quickpwn.
    Here is how to restore your ipod in itunes.
    You will need to put the itouch in DFU/Recovery mode to get it to connect.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
    Hold the Home Button down for 5 second (do not release it)
    Then Press and hold the Power Button for approx 10 secs (count them out)
    Your iPod will reboot.
    Release the power button and continue holding the Home button for an additional 27secs.
    You may see the screen go blank or not.
    Plug the USB end into the computer with itunes open.
    Your ipod will mount in recovery mode.
    Restore it and Your all set.
    if you need any further help let me know.
    Good Luck
    Jun 01, 2009 | Apple iPod touch
    I dont know what to do please help me my ipod touch is disabled.
    press and hold the home and power buttons, when it turns off DO NOT let go of the home button continue holding until it restores itself then connect it to your computer and restore it. unfortunately it will erase everything.
    Feb 02, 2009 | Apple iPod touch
    Apple iPod touch Logo
    524 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Sean Cole
    Sean Cole
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
