Question about ASUS Eee PC 1005HAPU17BU Netbook
Always hang up.,how to reformat and restore factory settings...??
How to reformat asus netbook model Eee pc 1005/1001 series? Always hang up when i'm surfing at the internet...
  • 185 Answers
How to format your hard drive and re install your operating system.
in order for you to do this you have to (before you format)
1. make sure that you have your recovery cd's or a cd/DVD with your operating system (windows or Mac)
2. try to back up all your information to an external Hard drive or DVD's depends on how much usable information you may have.
3. try to handpic your files to back up because if you do an auto back up you will end up with the same problem again.
-- to do a back up copy all your needed files to an empty folder and then burn them to DVD's or copy to an ext. HD.
4. after you do that (if you have your recovery cd's) insert #1 and restart your computer it will tell you to press any key to start from cd do that and follow directions.
5. when the program shows your partitions go ahead and delete them all, you need to end up with one
6. when you see just one partition go ahead and click continue and it will install your new operating system
7. if you have more than 1 cd it will ask you to insert the next one and so on.
8 after it finishes installing, get the cd out and run the setup process like if you've got a brand new computer, type the information and keep clicking next.
9. at one point you would be on the windows screen and that is it you have a brand new operating system.
Note: take in consideration that when you follow this process, you
erase EVERYTHING from the system including files and programs so after you do this you are going to have to re-install all your programs and copy your docs. back to the pc.
**** If you don't have the discs
check under start-(all) programs - start up- recovery- disk creation.
that (if you have it) will help you to create your recovery disks try to use 2 dvd's if posible if not you may have to get a windows cd to re- install and install drivers and apps.
if it works for you don't forget to rate me
thx
Posted on May 26, 2010
Restore factory settings for a asus Eee PC 1005HA
It should have a hidden partition that contains the data for your OS, more or less press F9 while your computer is booting and look for something along the lines of Factory Default, or Factory Reset. or Reformat.
Another thing you could do is use an optical drive and a windows disc to re-install everything. But you might need an external disc drive for that :(
I hope this helps :)
Feb 23, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
RESTORE asus TO FACTORY
This WEB site will giuide you in restoring your ASUS notebook back to the factory setup.
http://en.kioskea.net/faq/4162-restore-an-asus-netbook-to-factory-settings
Apr 18, 2012 | ASUS Eee PC 1000H Netbook
How do I restore my asus eeepc1001 series to factory default?
The Asus EEE units come with a Restore Disc. all you will need to do is plug in an EXTERNAL USB CD/DVD DRIVE, and load the disc on bootup (cold start) it should start running the recovery for you and will destroy all data on the drive. If you dont have your Restore Cd anymore asus did have a few models on the net for download ar you can request a restore cd from ASUS.COM under the contact us page
Hope this helps
Feb 15, 2011 | ASUS Eee PC 1001P Netbook
I need to restart the netbook to go back to factory settings
You will need the following items:
1. External USB DvD Drive; Can be purchased from local retailer
2. Your Asus Eee PC Restore Disk; This should have come with your netbook. You can order an additional disk by calling Asus, 888- 678-3688.
3. Once you have the above items be sure all your photos, music, documents, data etc. are backed up to a flash drive or dvd. A factory restore of an Asus netbook will ERASE all personal data on the hard drive. You must back up the data on another device in order to preserve it!
4. Connect the external DvD drive to your netbook and insert the Asus Eee PC Restore Disk.
5. Restart the netbook and boot from CD (usually the default key to boot from CD is F12).
6. Follow the onscreen instructions that are on the restore disk.
7. After installation of all software, update windows and reinstall all your necessary software.
8. Enjoy!
Jan 24, 2011 | ASUS Eee PC 1000H Laptop
Asus Eee PC 900 (white model) At startup, I get this message, "A disk error occurred Press Ctrl+Alt+Del to restart". When ctrl alt del is pressed it just takes it back into a loop and get the same...
Try presing F9 whilst booting(every other boot) to take you to factory restore pages select system recovery or discscan then press "E" then"B" etc and reset OS
Sep 10, 2010 | ASUS Eee PC 900 Notebook
How can i get Asus Eee PC back to factory settings?
Hi. Actually when you restore your system to its factory settings it will restore everything on your computer including the original operating system, but if you're saying that you have installed windows 7 on it then try going to ASUS driver support website, just type in their the model of your machine and it will ouput every software and drivers available for laptop and also different versions of operating system, So just choose the correct OS version for your laptop. Hope this Helps
Jun 04, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How to reformat ASUS Eee PC 900 notebook?
I have the linux version, not sure if you have the windows version or if it really matters. If you are looking to "reformat", you can go with the other suggestions with the USB stick. However, if you are reformatting to get back to the default settings, power on the computer and immediately hold F9. This will bring you to a screen that gives you the option to "restore factory defaults". You will lose all your previous settings, but if you were reformatting anyway, that's probably not a big concern.
Jan 13, 2009 | ASUS Eee PC 900 Notebook
ASUS Eee PC 1005HAPU17BU Netbook Logo
656 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
