Question about XtremeMac Airplay FM Transmitter for Apple iPod
Will not turn on when i plug into ipod - XtremeMac Airplay FM Transmitter for Apple iPod
  • Destiny Brock
    Destiny Brock May 26, 2010
    my XtremeMac Airplay will not turn on when plugged into my ipod
  • Destiny Brock
    thankyou i will clean connection points and try it again. it worked once or twice so prbly dirty
  • 4,924 Answers
This stuff it do not power itself from the ipod cause it is on a 3.5 jack ..so it has a battery ..and it is the only thing that you should verify cause it do not has any other controls but the +and- in frequency ..so ..check the battery and change it ..or see the contacts of the battery to be in place...also verify if you plugged it well..cause sometimes from the hurry you may plug it other way around
Posted on May 26, 2010
  • Catalin Turcu
    Catalin Turcu May 26, 2010
    I checked again and it seams that it has a power connector after all..so ..that may be the issue ..see to be cleaned and you may also try to see if you power it with a similar voltage source if it does..power up..just try a dc adapter ..from the ipod..if you have a way to improvise...an old phone charger will do ...just take 2 wires and verify if it does power itself.....
    or see what voltage has the ipod battery and use a similar source ..cause it may be the power plug from the ipod to blame ..or so ..and in this case you may try to reset the ipod ..(Iphone ) to see if it get back to the powering function ...and the other side is if with an external power source that device is not caming alive ..than it is either dead for good..or it has a loose contact ..and needs to be checked with a measurment tool to find the break in flow..
  • Catalin Turcu
    clean the connection point inside the ipod also ...use something with alcohol...even a perfume works if you do not have anything else in handy ..cause my suspicion is that it do not makes contact cause of the ipod..probably something got inside from the pocket ..
    Brigadier General:
  • 3,917 Answers
Hi
If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. A lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen. If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting
Sync in Progress. Do not disconnect. If your iPod is frozen or won't turn on then check for the correct model in the bellow link.
http://support.apple.com/kb/ht1320
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
I don't know why stop my ipod
Greetings Aek Smarth,
Your ipod has probably overheated. Here is what you should do:
  1. Turn on your ipod and let it play until it dies.
  2. Plug in your ipod and fully recharge it.
If your ipod is unable to be turned on:
  1. Plug it in and charge it for over a day.
  2. Attempt to turn it on after this day.
After having it plugged in for a day, it should reset itself and be like normal. If it does not reset itself, than your out of luck. Thank you for using FixYa! =)
Nov 18, 2010 | Apple iPod MA446LL/A MP3 Player
The speaker on my ipod plays even when my headphones are plugged in. How do i turn off the internal speaker?
un plug ear buds
reset ipod by holding menu and center at the same time for 30 seconds till you see the apple logo - - then reconnect ear bus make sure they make a clicking sound and there is no gap
play a song to test
Apr 05, 2010 | Apple iPod nano
The internal speaker for my ipod nano will NOT turn off
The speaker on my new Ipod nano the one with the camera won't turn off when i plug the headphone in it. Help please :(
Feb 11, 2010 | Apple iPod nano
Ipod nanao 2 gb problem
Have you tried plugging it into your computer and restoring the programming? Also, you can try pressing the menu and the center button at the same time for 10 seconds. It should go black (turn off) and then turn back on with the Apple logo. If this doesn't fix your problem, you got something wrong with the hardware, not software.
Jan 19, 2009 | Apple iPod nano MP3 Player
2nd Generation iPod Shuffle Wont Turn on and 3 orange lights sync
ALLOW IPOD TO RUN DOWN..BY LEAVING ON.THEN FULLY CHARGE.TURN ON AND IT SHOULD RESET ITSELF IF NOT LET ME KNOW.I WILL ADVISE FURTHER.RICHARDM69
Dec 04, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod not turning on or charing with computer
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If that is not able to fix your problem, contact apple or your dealer for more assistance or repairs.
If you need more assistance let me know. Good luck.
Jan 31, 2008 | Apple iPod nano
My ipod nano wont do anything
Did you try resetting the iPod? If the battery were dead then when you plugged it in, you'd still see something popping up on the screen. What's possible is that your screen got disconnected from the iPod logic board or otherwise got ruined. When you try turning the iPod on can you hear any noise inside? If you toggle the hold switch does it show the orange light? If you can't hear any noise and it doesn't show the orange light, your iPod's logic board probably died. You can get a new one off eBay and replace it if you're comfortable opening your iPod. Otherwise, you can sell the broken iPod on eBay for a decent amount.
Jan 06, 2008 | Apple iPod MA446LL/A MP3 Player
XtremeMac Airplay   FM Transmitter for Apple iPod Logo
50 people viewed this question
Top XtremeMac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a XtremeMac Audio Player and Recorder Expert? Answer questions, earn points and help others
