Question about Sony Handycam CCD-TRV37 Camcorder
Error c 31:10 appears plus the eject icon, every time I insert a tape.
SOURCE: Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Posted on Jun 16, 2008
SOURCE: error C:31: in Sony DCR-HC42
Same here. When I place cassette into the carriage and snap it shut the servo does not activate to pull the carriage in the rest of the way. Has anyone found any tech solutions for this?
Posted on Aug 18, 2008
SOURCE: Error code on DCR-TRV530 - C:32:10
Thanks Tonrey11, it worked to me, as well.
Posted on Sep 15, 2008
SOURCE: Sony Video 8 TRV30E Handycam keeps ejecting tapes
I was having the same problem. I just gave it a few gentle smacks from every angle possible and it quit acting up.
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: error code c:31:22. beeps. flashes eject sign
This is a very common problem with many of Sony cameras. Please tap the camera at its bottom and left side a few times after removing the battery. I am sure that its going to work for you.
I have this problem repeatedly coming up for my cam and I solve this by this home made remedy !
Posted on May 29, 2009
I turn the camera to record and it blinks an icon which resembles ejeciting the tape. It is a triangle over a line. It also blinks "C:31:23" It will not allow me to record. What is it?
You need to try to eject the tape and put it back in the camera. That error means that something has happened with the tape transport and the camera could need a cleaning tape but not necessarily. Try re-inserting the tape. If the error appears again, try a different tape. If the error still appears, run a cleaning tape in the camera on playback for 8-14 seconds (no longer!). Then put a regular tape back in. If you still see the error, there is probably a mechanical problem in the tape transport and the camera will need to be repaired. It's possible it could just need a clean and lube on the mechanical parts, but in any case you will need to take it to a camera shop for an estimate.
Nov 30, 2010 | Sony Handycam DCR-TRV330 Digital Camcorder
Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Aug 13, 2008 | Emerson EWV403 VHS VCR
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
Error Message and tape is hung up on the drive mechanism.
check the drive belts in both decks. they stretch with age.
Nov 07, 2007 | Rio Go Video GV6060 Dual Deck VCR
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
VCR Tape Stuck
my tape got stuck too, i opened the bottom, then located the mechanism that started the eject program. After turning some wheels the eject automatically started. Try that...
Sony Handycam CCD-TRV37 Camcorder Logo
74 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
