Question about Amana ABB2224D Bottom Freezer Refrigerator
REFRIGERATOR AND FREEZER STOPPED WORKING. COMPRESSOR IS HOT. FAN IS WORKING. IT TRIES TO COME ON. IT HUMS FOR ABOUT 15 SECONDS THEN STOPS AND TRIES AGAIN
Fridge and frezzere stopped working. Odd smell almost like overheating. Couldn't adjust the temp dials seperately they both were at same number and if you adjusted it automatically adjusted same on each dial. Unplugged the unit, lef *** and then plugged it in and it seems okay?
Posted on Aug 05, 2010
    President:
  • 2,468 Answers
Replace the ptc overload relay on the compressor body,it merely unplugs and a new replacement plugs in,available from any appliance parts distributor,they get weak and will not stay "latched" to keep the compressor powered due to high heat and current draw after so long
Posted on May 26, 2010
My refrigerator is 15 years old. it has a top freezer. has been a good refrigerator until a few weeks ago. the motor is a lot noisier and the area around the freezer door ( top and sides) is really...
The compressor may be short cycling due to a condenser fan stopping while the compressor is running. The heat you feel is coming from the hot gas cycling through what is called a yoder loop. The yoder loop is there to prevent moisture buildup around the door seal. When this area becomes hot it means that something is wrong with the cooling fan below the refrigerator and cleaning the area may help. Please be aware that the fan may appear to be running normally but keep an eye out after cleaning because a bad fan does not always stop all the way and I have made up to three trips before catching one that has stopped. Always unplug the power before attempting to reach inside the compressor area. Feel compressor top to see if warm, hot or too hot to keep hand on top. Again this problem can be the condenser fan, dirty condenser restricting air flow or the start components of the compressor are worn out or all of the above. Fixing this now may extend your refrigerators life another 10 years. If you have any questions I will be here to assist you, Thanks, Sea Breeze
Jun 13, 2011 | Magic Chef Refrigerators
Maytag freezer does not work. it hums and stops
if you evap fan is not working this wouldnt produce any coldness,, or possibly it sounds like your compressor start realy is tryin to start but not working,,,
Feb 03, 2010 | Maytag MZD2665HE Side by Side Refrigerator
Bad capacitor/relay or compressor?
that is most likely a relay. Does the unit get cold while running?
Oct 23, 2009 | Amana ABB1921DE Bottom Freezer...
So-low freezer try to start, but stops after a second
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Side by side whirlpool refrigerator with easy water and ice, not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Whirlpool refrigerator
you can try replacing the overload relay mounted onthe side of the compressor ( kit number 4387835) sounds like its gone bad, trying to start yor compressor, but tripping off on overload.
Jan 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the...
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Jul 03, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Amana Refrigeration stopped running
If the compressor is at room temperature and no noise coming from it your problem could be the thermostat control. If the compressor is hot and you hear a hum followed by a click the compressor may have failed. Check the condenser and make sure it is clean. In those operating temperatures the compressor is overworking in the first place and if it is not getting free air flow across the condenser it can burn out. Best condition for operating any refrigerator is to remember that if you feel hot it feels hot. They are designed to operate in an place where we live and at the temperatures we live in.
Jun 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Amana ABB2224D Bottom Freezer Refrigerator Logo
233 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
