I have a 32" HD DVD combo Insignia LCD flat screen TV. For the last month when you turn on the TV w/o cable the TV stays on for 1about 30 seconds then a clicking noice from the back of the TV happens and then the TV automatically turns off by it's self. We call our local Cox Cable conmpany and theya re saying that it is not the cable box or the cable cord that you connect to the back of the TV. A friend of mind gentle and very very slowly insert the cable cord into the TV and the TV worked for 2 days. I turn the TV to the place where I bought it "Best Buy" and they plugged in the TV and they said it work and they did not assit me at all. Several local TV repair places here in Las Vegas, NV all are stating that it will cost me $200.00 just for them to look at it not if they can fix it. The same problem also occurs when the cable box is not connected to the TV and you insert a DVD the TV shuts off within 30 seconds. Are you able to assit me w/my TV or trouble shoot. Note: I paid $699.00 for this TV 11/25/2008. PLEASE HELP; HOME OF 2 GRANDKIDS WITHOUT CARTOONS AND SPONGEBOB. Janet Contreras 702-261-9167
  • 19,396 Answers
Hi Janet.
Hi.
The TV is forced to stand by when there is an incorrect voltage value detected from the main controller board. When this happen the main controller is forcing the PSU to standby, sending the TV in protect mode.That is the clicking noise that you hear.
The PSU can be tested bridging the low voltage control lines that are turning the higher DC volts from PSU on.
The procedure to test the PSU is illustrated in the following article: How to test an LCD TV or monitor PSU
Bridging the voltage lines is a repair suitable for an experienced technician. If you are a DIYer, better testing the resistors and components near to the faulty capacitors by reading Ohms to check if they have continuity. This operation is done with power not connected.
If you need to replace the whole board, here you will find the part : ShopJimmy
Both power board and digital board may be responsible.
Posted on May 26, 2010
We received a second hand 32" insignia about 2
The display panel is bad and to expensive to fix. You can check the board at the top . This is the T con board . Be sure that the flat cables ans pluggin good.
Mar 21, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Green screen using HDMI input
Try using the RGB component input and see what happens. If it's normal, then you might have a software issue in the set. You'll get the same quality out of RGB as you would HDMI.
Dec 18, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Used insignia 32 inch with DVD. want to reset
most manafactors codes are 1234 or 0000 or 5555 or 8888 you might have to put extra didget on EG 12345 -00000 - 55555 -88888 but if you changed it sorry dont know
Nov 10, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
I have a 32" HD widescreen LCD TV/DVD combo. TDA03211c. When I put a dvd in to play it makes a noise and puts some digital garbage on the screen. Will not play dvds.
Sounds like the DVD player is defective. Just food for thought.. Try not invest in any make with a built in DVD player, they just don't last.
Oct 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
