Question about Sunbeam SCA103RWB1 Room Air Conditioner
Digital sunbeam air conditioner
The air conditioner was left. It has power but we dont know how to set and receive power. Thanks
  • 67 Answers
SOURCE: sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Posted on Jul 14, 2008
SOURCE: Sunbeam floor air conditioner KY25/Y
Mine is cooling but I have a broken fan. If you're not going to use it sell it to me please. contact me at yenks@hotmail.com
Posted on May 24, 2009
SOURCE: e2 CODE ON SUNBEAM SCK14200DR
I just fixed this on mine one minute ago.
Take off the front panel.
You will see a black wire held onto the heat fins by a plastic clip.
This is the thermocouple that measures temperature.
Mine became unplugged from the circuit board and plugging it back in fixed the problem.
The wire goes into a steel box.
take off the screws on the bottom of the box, grab it by the lowed left corner and bend the metal up as far as you can.
The wire plugs into a small white connector on the circuit board.
plug it back in, bend the metal back down, screw it in, replace the cover, and you should be good to go.
-Alexander W MacFarlane IV Ph.D.
Posted on Jun 10, 2009
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
  • 52 Answers
SOURCE: Sunbeam Model No. SCK 14200 DR no cooling...
Un plug a/c from wall and remove the screws from the electrical compartment of the unit and locate the thermostat, remove the 2 wires of the thermostat and use ohms meter to check the part for continuity, if you dont have continuity with t-stat turned down below room temp., replace thermostat.Good luck.
Posted on Mar 07, 2010
Testimonial: "When I hold the thermostat in my hand the digital temperature goes up. Is that proof that it is working?"
Whats the right settings for the window air conditioner.
i operate my a/c's in summer at 72 to 74 degrees. in the winter at72 to76.
Jul 30, 2015 | Fedders AED24E7F Wall/Window Air...
E on controlls
If you have a digital control, it is designed to flash "E" on the display to notify you that a problem may have been discovered. Gradient controls and warming throw controls use a blinking indicator light for this purpose.
Follow the instructions on the flag tag to reset the control or follow the steps below.
  • Unplug the system from wall outlet.
  • Check that the control is well connected to the module.
  • Plug the power cord into the wall outlet.
  • Set the control to "on".
If the system still does not operate, disconnect the power cord and contact sunbeam
Sites sunbeam Site
Jan 11, 2015 | Sunbeam Twin Heated Blanket Navy Blue...
MY AC KNOB IS BROKEN, HOW CAN I GET THIS PROBLEM FIXED
If it's just the plastic knob that's broken, go to the following link to find one like yours.
http://www.appliancefactoryparts.com/airconditioners/sunbeam/sunbeam-knobs.html
Or check your Owners Manual concerning how to get replacement parts.
Thanks for choosing FixYa.
Aug 10, 2011 | Sunbeam SCA052MWB1 Thru-Wall/Window Air...
I want to set up the model option for the air conditioner sumsung sh12bwha, becouse it doesn't respond, all lamps of indoor unit are flickerng and i dont know the option number. please help
Hi Annita777a, If all the lights are flickering, that sounds like a fault. I suggest that you turn the power off at the wall, wait 5 minutes and then turn the power back on again. If the lights are still flickering, maybe call a serviceman or ring the suppliers for a phone consult
Feb 23, 2011 | Heating & Cooling
Sanyo sap-71a will not start using remote the remote will start other air conditioners thanks
Simple, remove power and then unplug DC wire from indoor display for 2 minutes.Again plug it, power on. And also remove batteries and re insert in remote and then use. If still problem, your signal receiving sensor defective. You have to repair/replace indoor PCB.
Feb 05, 2011 | Sanyo 12KHS71 Split System Air Conditioner
Heater dont work
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV. If it's with heating element check power to element. If power is there but still no heat means element defective. Replace new heating element. Thanks.
Dec 31, 2010 | LG LWHD1807HR Thru-Wall/Window Air...
Mar 05, 2010 | Sunbeam SCA103RWB1 Room Air Conditioner
Sunbeam SCA103RWB1 Room Air Conditioner Logo
52 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
