Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Dirt Devil R088100. Cloth Was Sucked Into Hole Below Dirt Holder
Hi All, A Lite Cloth Was Sucked Into A Hole Below The Dirt Collection Aria On The Left Side Of My Dirt Devil Model R088100, That Is The Left Side While Facing it.
After Part Of The Cloth Was Sucked In, The Motor Slowed And I Turned It Off. I Managed To Pull Most Of The Cloth Out And Turning It On again And It Emitted A Burning Smell And Then Stopped.
My Question For You, (If You Can Help Me): Is The Motor Fried Or Is It The Cloth That Is Heating Up, Burning, And Stopping The Machine? If It Is The Cloth, How Do I Open Up The Dirt Devil And Get The Cloth Out. Thanks Brad
  • 3 Answers
Brad, Hopefully it is the belt that you smell burning. I would start by removing the underneath side of the vacuum head. Normally just a few screws that are meant to be remove for general maintanence and circumstances such as this. After removing the screws this should reveal the dirty side of life to you. You may need to remove the roller brush, and inspect the ends to make sure the brush rolls freely while holding the ends. If not the ends may need to be cleaned of hair and strings: ends should pop of and a shaft runs through the middle connecting them. Clean and replace. Move on up the path the dirt travels. The neck where the head and vacuum come together is the next jamming point, if this is where the cloth is lodged chances are the motor may have over heated due to clogging. Your vacuum may have a automatic shut off. You will need to contact Dirt Devil to see if there is a reset for the motor. There are propellers / fan blades at the end of the neck just before the motor housing. This is most likely where the clothe has logged itself causing the brushes on the electric motor to emit the burning smell, if you can remove all obstructions and the unit still does not turn on, check with dirt devil about the reset, Hope this helps.
Posted on May 26, 2010
Dirt Devil easy lite vacuum makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi there! Sounds like that noise may have been your belt popping or breaking. Try checking the belt on the vacuum. If it has broken, replace with a Dirt Devil style 15 belt. Below is a link where you may go to purchase the belt if needed. Thanks!
Style 15 Belt 2 Pack
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
Dirt Devil easy lite makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi, it's Cindy from Crucial Vacuum.
From your description, it sounds like there may be something stuck in your roller or your filter may need cleaning or replacement. Refer to page 22 of your manual to remove your roller.
For optimal performance, your filter should be replaced every 3-6 months and washed every 1 month. Your filter is located under the dirt cup holder.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f43-easy-lite-cyclonic-hepa-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
My dirt devil wont turn on
first thing to do is to look in the dirt container for what masy have been sucked up.
Nov 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
I accendenty sucked up the cord to my son's headset and it wound around the beater bar. I got the cord out of the bar but now the bar doesn't work. Any help would be wonderful. Linda
The belt probably broke and needs replaced. Make sure you get a new belt made for that model to use. Steps for replacement depends on what model you have, and are found in the manual. You should be able to find a manual for your machine using the Dirt Devil site below.
http://www.dirtdevil.com/search.aspx?type=3
Mar 02, 2011 | Dirt Devil Vacuums
How do you empty the dirt out of it
The plastic dirt holder should have a lever that opens the canister.Should come right out with a slight pull.empty contents into the trash.
Oct 21, 2010 | Dirt Devil Easy Lite Quick Vacuum
Hi, I have a Dirt Devil Model # M08100REDC. I desperately need to change the bag, but I don't see an obvious way to do it. I'm afraid to try pulling on the cloth tab thingy that's just below the handle,...
You can pull on the tab to remove the bag, but probably a better way is to gently pull on the rubber ring that attaches the bag to the back of the vacuum body. If you don't yank and ****, it should come off without spilling the dirt. There may also be a paper bag actually catching the dirt inside the cloth bag. If there isn't, I recommend you get a package of those. They come in packs of three, and they're disposable -- instead of emptying them, you toss them and install a new paper bag.
Sep 03, 2010 | Dirt Devil Classic M08100 Bagged Handheld...
Help!!!!
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
410 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
