Question about Onkyo TX-SR606 Receiver
Searches for signal and then states not supported, using cable television
  • David Dunn
    David Dunn May 26, 2010
    What signal is being provided on what interface? Maybe it ISN'T supported.
  • rpollard643 May 26, 2010
    It will not pick up High deff video signal, it searches for a signal and then the tv will show a message "not supported", it will pick up non high deff signals.
    Brigadier General:
  • 8,546 Answers
And the interface(s) involved? We need details to formulate answers.
Is the message from the TV? Perhaps we should be looking at what the TV supports.
Posted on May 26, 2010
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
Can not enter menu
It looks like you have the Source Select to "ypbpr".
Press the menu button to display main menu.
If this is the first time you have used a Digital TV you will have to do the following.
> Connect the signal source either antenna or cable to the back of set.
> Select the same signal source in the menu. CH
> Choose submenu between TV and cable
> Scan the channels. Auto Search
>Save and exit the menu. Press OK
You can get the Owner's Manual from;
http://www.retrevo.com/support/Polaroid-FLM-3201-TVs-manual/id/279ag015/t/2/
Feb 11, 2011 | Polaroid FLM-3201 Television
I got an American model of LG. i can not tune it by auto nor manual can you please help
You can get a manual here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LG30.jsp . Click on the Support and then on the right hand side look for User's Manuals. Since the TV has a tuner for ATSC, NTSC, and Clear-QAM, the next question is what is your signal source? (analog, digital and unscrambled cable)
If you are using OTA, make sure that the input is set to Antenna. Use antennaweb.org or tvfool.com to check the direction to point your antenna and the appropriate antenna for your distance to the transmitter. antennaweb assumes an external antenna and is very conservative in the list of channels you should be able to receive. tvfool gives the stations available with different antennas. If you have several tvs connected to one source, you may need an amplifier in addition to the splitter. This also can help marginal signals come in since digital is either enough for the tuner to resolve or no signal. (Check splitters and amplifiers if you suddenly can't get a signal that you used to receive. Also check if the antenna has been turned.)
Menu > Channel > Auto Tuning or Manual Tuning. If Lock System is active, you will need the password. Auto Tuning only searches for digital or cable channels. The manual tuning option should provide the signal strength as well for digital stations (as well as letting you search for analog signals or all signals (digital, analog, cable).
Use the input Cable for coax cable connections. Other inputs will not allow you to search for channels since they are meant to be controlled by the set-top box feeding the system.
I hope this helps.
Nov 05, 2010 | LG 32LG30 32 in. LCD HDTV
It will but in the middle of a movie it just cuts off
I am assuming you mean the picture hesitates,skips or freezes.......I also think you mean the tech said it needed a "tuner" This could be tru if you are watching over the air signals,but if this is happening on cable,satellite....using the hd inputs(hdmi or component),I would suspect the main signal board or even the cable or satellite signal strength.
Jun 02, 2010 | Olevia LT32HVM 32 in. LCD Television
3 rooms with dish works on 2 on 3rd i get no sync
This problem could be caused by a weak signal amplifier in the tuner section of the Television. You can try putting the television in a location where it will receive a stronger signal from the Dish. Closer to the source of the signal. You can also try getting a signal amplifier to increase the signal strength to the television tuner.These amplifiers are usually sold at the local electronics stores like Fry's or the Micro Center. You can call the stores and ask them if they have signal amplifiers for cable and satellite signals. You can also find them on line by using the search engines looking for signal amplifiers for cable and satellite signals. If all this fails to solve your problem, Call the Insignia customer support at this telephone number 1-877-467-4289. Tell them the model number of you television and the problem you are having with the loss of signal reception. They should be able to tell you how to resolve the problem. The customer support website is www.insignia-products.com. you can use the customer support section here also to explain your problems. I hope this information helps you with your problem.
May 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Grey Screen with 480p signals (or higher)
I've had a KP 53HS10 for close to 8 years I think. 4 years ago the picture started blinking after long use, then more and more often. I had a repairman come and replace the tuner card (that's all I know about what he did). Now that I finally have HD from cable, I've found that 720 doesn't work and 1080i works, but the picture blinks on and off apparently struggling with some inner problems. Everything looks great, for a second and then it blinks. The red light blinks 5 times repeatedly while this is going on. I called SONY 5 times means get a repair man. I searching forms like this for help as well.
Nov 18, 2007 | Sony KP-53HS30 53" Rear Projection...
HDMi ( no signal, not supported) doesn't work with Dmr
I have lost my manual for the lct27ta. Have you gone into the menu and setup the hdmi port?
Oct 09, 2007 | Akai LCT2785TA 27 in. LCD Television
Tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Sep 17, 2007 | Sanyo DP26746 26 in. LCD Television
Onkyo TX-SR606 Receiver Logo
87 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
