Question about Refrigerators
We have a freezer that turns on 1 1/2 then kicks
We have a freezer that turns on 1 1/2 minutes then kicks off not freezing, its kicks back on but will not freeze
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerwe have a freezer that turns on 1 1/2 then kicks - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 26, 2010
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Hi - We've got a Turbo Air TGF-23F mrechandising freezer that freezes - down to -15 and then suddently begins to warm up about 1 degree per minute. In about 15 minutes its just over 0 degrees and...
Did they test the thermostat? I would think that the compressor would kick on before you got that much of a fluctuation, unless the thermostat is not sensing the change fast enough.
The run and start capactiors and relay, did they give you a reason for that? When the compressor kicks on does it surge the power? Light dim or something? It is hard to guess without being able to put an o'scope on your machine to be able to see what it is doing, but just based on what your write-up was, I can't see the parts you said they want to replace will fix the problem.
Jun 08, 2011 | Turbo Air Freezer 23 cu ft Single Glass...
Not cooling/freezing
Hi!!
Check
temp. control knobs,
Small fan in freezer, it should start working after opening the freezer door for a couple of minutes. If it does not start, use a pen or pencil to turn the blades, if it kick in, replace motor.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear.
Once this is done, restart unit
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Frigidaire Refrigerators
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Will not freeze
either overload and relay or compressor run windings are bad
May 25, 2010 | True 11.4 cu. ft. / 323 liter Upright...
Side by side refrig. side not working;freezer freezing up
The unit is not defrosting. Either the defrost clock is defective or the defrost heater is not working. Defrost clock is normally located behind the bottom kick panel. Use a large standard screwdriver and turn the center screw clockwise very slowly until the compressor stops. Wait 20 to30 minutes the compressor should restart, if not the defrost clock is defective. Checking rhe heater you'll need a vom meter or amp meter.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer will not freeze
it may be the timer (timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32
Aug 26, 2009 | Refrigerators
Sanyo Eclipse refrigerator (Model# SR-4433S)Has puncture hole in Freon Tray for freezer. Does anybody sell replacement part?
HI thanks for the question. if theres a puncture in the coils . scrap it way too expensive. sorry.
Oct 15, 2008 | Sanyo Refrigerators
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
