Rinnai 2001 Gas Heater - turn off
My gas heater turns off after about ten minutes. I am assuming it is a safety feature when the thermostat gets to hot. The cuase I don't know. I paid a repairer $99.00 12 months ago to vacuum the heater, but it still keeps happening. Any ideas?
Cheers, David
Melbourne
  • 1 more comment
  • seaweedsuck Sep 06, 2008
    I have a Rinnai 2001 Gas heater that the pilot light ignites the main flame, then after several minutes when it heats up the fan comes on but the main flame goes out and the fan continues to run until cool, then the fan turns off and you can start the pilot light and continue the cycle. I have disconnected the fan and the main flame will continue to run.
    Any hints would be greatly appreciated.
  • graham_david Nov 08, 2008
    I have a Rinnai Rinnai REH301EB Space Heater, when the heater has been on for several minutes it turns it self off, I am assuming that the thermostat is kicking in, when it does this though the pilot light goes out to, anyone have any solutions
  • Anonymous Apr 28, 2009
    I have exactly the same problem except the space heater is Rinnai model REH300FTC. I vacuumed it but to no use. Can you tell me did you fixed your problem? What was wrong? Or shall I rather look for a new heater?
If, like me you have a Rinnai **** heater, with a PCB Assembly, then thats what the problem is. Look at around $500+ installation. These PCB's are not repairable. For $500, I am going to trash this heater and get something from a company that does not want to screw me after I have trusted them to live up to their "REPUTATION". Do not support companies that do not support their customers!
Posted on Oct 15, 2009
    Scholar:
    New Friend:
  • 70 Answers
When the repair guy cleaned water heater did he run white vinger through the coil inside the heater. Does the control pad show any errors
Posted on Apr 18, 2008
  • Scott Magill Apr 24, 2008
    what model is it? Have you taken out the filter to make sure there is no restriction of water flow.If you have a manual look on page 43 it will tell you the flush procedure. If you don't i can send you the page.
MAXI hEAT CERAMIC HEATER CH 110
Possible problems:
Adjustable thermostat dirty or worn out. Can bypass thermostat with a wire, if you do this thermostat will not function since it has been bypassed.
"Too hot safety piece" (located between large yellow and large white wire) is dirty between contacts. Disassemble, clean with sandpaper, reassemble.
Nov 21, 2013 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
The difference between thermal fuse and thermostat
Thermal fuse is a heat-sensitive safety feature that shuts down system when overheating is detected.
In electrical wiring, the thermal fuse reacts to high temperature caused by too many amps on the electric circuit. When temperature exceeds the fuse amp rating, then the fuse trips and cuts power to electric circuit.
Example of thermal fuse is a household circuit breaker.
Gas water heaters have a different type of thermal fuse located in the combustion chamber or on the combustion chamber door, and also inside a copper probe inside water tank. Water heater thermal fuses will trip when water temperature exceeds fuse rating, or when heat inside the combustion chamber exceeds temperature rating of fuse. This action will cut off gas supply to water heater.
So a thermal fuse is a safety feature.
Thermostat is not a safety feature.
Thermostat is a measuring tool.
Thermostats measure temperature.
Example of thermostat is outdoor thermometer, or cooking thermometer, or Heat-AC control located on wall inside house.
Thermostats can give a simple temperature reading, or they can cause a separate control to turn on-off depending on application.
For example thermostat on Heat-AC will read room temperature, and when temperature exceeds setting, this triggers a switch that turns Heat-AC on-off.
Many appliances have both thermal safety fuse and thermostat.
Take for example a gas water heater. A copper tube extends into the water tank. Inside the copper tube are 2 things: A thermostat probe to measure water temperature, and a thermal fuse called an ECO for energy cut off. The ECO is a thermal fuse, and is a safety feature.
http://waterheatertimer.org/images/Gas-valve-ECO2-358.jpg
The thermostat reads temperature of water, and turns water heater on-off to keep water hot. A person can adjust water temperature by adjusting the thermostat dial on front of water heater.
However if the thermostat fails, or some other problem occurs, and water inside the tank gets hotter than 180 degrees, then the ECO or thermal fuse will trip. When the thermal fuse trips, this turns off gas to the water heater so water cannot get any hotter. The safety device prevents water heater explosion. The water heater must be repaired since this particular thermal fuse cannot be re-used afterwards, and must be replaced.
Oct 11, 2012 | Dryers
Difference between thermostat and thermal fuse
Hello Mary
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
My heater runs for about 10 minutes then the flame cuts out and can't be turned on again till it cools down for half an hour...
Hi.
Replace the flame sensor, if that does not fix the problem, check the thermostats, if it cuts off in ten minutes and then restarts when cooling down, then it is either flame sensor or thermostats.
Sep 24, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
My rinnai comes up with a code 11 when i try to start it. if i try it about ten times the main valve opens and runs fine. but untill that point it doesnt start. any ideas?
Mysolution relates only if you are on LPG/bottleg gas. I have had many problems with the gas regultor actually on the initial supply line near the bottles sticking. Error code 11 is usually simply a gas supply issue and not a fault with the heater itself. Just rule out that before you start messing with the heater itself. Causes inside the heater would be either gas valve (unlikely) or PCB. Both are not normally intermittent. Try running something else on gas if you have anything and then turn on the heater.
Sep 15, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai gas water heater wont heat the water hot enough even though we have turned the thermostat up to 185.
your temp control is bad and you will have to have a tech to service the unit, contact rinnai and they will give you info on a quilified repair person,, not just any one should be allowed to work on it,, depending on the age it may still be under warranty,, they come with 5 year parts 1 year labor 12 years on heat exchanger this is on all rinnai units
Feb 18, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Converting Rinnai REH-25-N to LP
Typically, an unvented heater or gas log cannot be converted, mostly for safety reasons and it is usually cost prohibitive. Some newer heaters come with both Natural Gas and Propane components and have to be set up one way or the either.
It would be better to sell your old heater and get one with the proper gas type.
Nov 23, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Rinnai 1004 error code 11
I had this problem and oops, the gas intake was closed. check the door on the right side of the unit, and make sure the valve is turned to "open" .... here's the link for the online manual if you want it: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf
Oct 04, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heater goes off
Possibly A bad thermocoupler. It is the part that looks like a stiff solid copper wire with on end sticking in the flame of the pilot light and is a safety feature if the pilot goes out it starts to cool and the resistance changes back you the module and the module shuts the gas off. I have seen these go intermediately faulty in waterheaters and do just what you described.
Jan 08, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heating & Cooling Logo
1,589 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
