My Whirlpool Duet Font Loader Washer stopped 1 minute before the end of the spin cycle; and I need to know how to reset it so that I can start another load of laundry.
  • 5 more comments
  • shawn1204 May 25, 2010
    I pressed the end of cycle button for 3 seconds, but this did not solve the problem
  • shawn1204 May 26, 2010
    I tried pressing pause and cancel and disconnecting the power for two minutes; that did not solve the problem.
    I pressed the pause and cancel button twice and then unpluged the washer and left it unpluged over night; that did not solve the problem.
    I ran the diagnostics test and got error code F22 and F34. What is error code F34
    Nedd help with F22 and F34 code. Also I accidentally triggered the door lock when I was checking to see if it was broke. How do I unlock it? The door is open, but the lock is locked.
    Did self diagnostics test got code F22 and F34.
    What is F34?
    Also I latched the door lock when I was inspecting it. The door is open, but the latch is in the locked position. How do I get it open?
  • michelle May 26, 2013
    stupid washer stops in the last minute of the cycle with the E1f6 error help....
  • Washing Mach... Master
  • 8,220 Answers
Remove the front panelMy Whirlpool Duet Font Loader - fbee677.jpg and check the pump filterd05d32e.jpg for objecMy Whirlpool Duet Font Loader - 8b65c4c.jpg"http://i.fixya.net/uploads/images/8b65c4c.jpg" alt="8b65c4c.jpg" class="h_mi" /> then grab the tech sheet behind the white box and use the diagnostic instructions.
You have any non-HE soap in there or 2 much the machine will overamp and act all weird and then shut down with error code flashing. If it is an F-21 it means a Long drain. Possible cause: ClMy Whirlpool Duet Font Loader - de495ab.jpgr, clogged/failed pump.de495ab.jpg
Posted on May 26, 2010
Testimonial: "Washer is fixed and has been working for the past week. I have a spare latch now, because I never had to install the new one. I also discovered that the start button was not functioning properly. That is why I could not get the washer to run after repairing the door latch. Thanks for all your help the repair manual that you sent me made things alot eaiser."
  • 11 more comments
  • Dan Webster
    Dan Webster May 26, 2010
    Go to the service matters link I am about to provide and there you can get tech sheet and manual
    SERVICE MATTERS
    look through these seldome seen service pointers for clues to the F-34
    SERVICE POINTERS
  • Dan Webster
    Thanks for the great rating.
    F01 power glitch: disconnect power for 2 mins verify correct CCU operation
    F11 Motor control unit internal failure MCU board failure or broken wire.
    F20 No water detected entering machine, pressure switch hose clogged
    F21 Long drain Possible cause: Clogged filter, clogged/failed pump
    F22 Door lock error Failed lock. corrosion,or broken wires.
    F23 Heater Failure Bad heater
    F24 Water temp sensor error Failed sensor or heater
    F25 Motor Tach error Bad MCU (motor control unit) or broken wire
    F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
    F27 Overflow condition Clogged drain, pump, kinked hose.
    F28 Com error between MCU and CCU (central control unit) Broken wire
    F29 Door unlock error bad switch,broken wire,corrosion
    F30 Dispenser system error Bad or jammed motor, broken wire
    F31 MCU failure due to motor overheating.
    F33 Pump drive system error, broken wire, corrosion
    rL (prewash)Clothes detect. Remove clothes and retry.
    5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
    The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
    For diagnostics and further info refer to this handy dandy:
    DUET SERVICE MANUAL My tip:
    http://www.fixya.com/support/r4232744-du...
  • Dan Webster
    The MCU may have confirmation of door lock but the CCU may not be getting it. This is caused by corrosion on the door lock connection. Simply unplugging the lid lock assembly and clean the contacts may fix it.
    I am going to try that now. But I still can not get the latch to open. I pulled down on the release handle,but nothing happens; the door is open and the lock is in the locked position; and will not move even when I stick a screew driver in it and pull the release handle.
  • Dan Webster
    remove the latch
    I can't get the plug on top of the latch off. Is their a trick?
  • Dan Webster
    Duet Service Manual
    printable version
    print out a copy and go over it
  • shawn1204 May 27, 2010
    Thank you for your help last night. I was able to remove the switch after reading the manual you sent me; and I ordered a new switch today. Will the trouble codes automaticly erase when I install the new switch, or is there something I need to do to clear them? I'm still not sure what F34 is or how to clear it.
  • Dan Webster
    Dan Webster May 27, 2010
    Yeah I think all will be ok if the CCU can read the switch.
    I put the old latch back in after I took it apart and checked it out; and I was able to run the complete diagnostics cycle twice, but I still can't run any of the normal cycles.
  • Dan Webster
    Dan Webster May 31, 2010
    Hows the repair going? Were you able to resolve the latch problem?
  • ThankfulMomm Sep 27, 2010
    Thank you for the tip!! Worked like magic!! My DUET was flasing F02 so I did exactly what you said and got a GLOB or stuff out of the drain pump including an antique ring I lost over a year ago! Still can't get over how those items got there!
  • Dan Webster
    Dan Webster Sep 27, 2010
    Thanks
    President:
  • 1,554 Answers
Press the Pause/Cancel button twice to cancel and stop the cycle and start a new cycle. Unplug the washer for at least 15 minutes to reset it should the Pause/Cancel button does not cancel and stop it.
Provide more information should you need further advice including the exact model number and codes flashing on the Estimated Time Remaining display, if there's any.
  • 2 more comments
  • Jahn27
    Jahn27 May 26, 2010
    The problem cannot be solved by mere resetting the washer because this a serious one that makes the user console interface board and the central control unit suspects. Indicate if there's any sign of power going to the washer such as lit or flashing LEDs on the console. The washer has a built-in diagnostics that flashes a code should a problem is encountered. Provide more information as we provide advice based on the information given by the customer. The more information provided, the more accurate the advice, and more chance the problem is addressed.
    Diagnostics can also be performed to verify the operation of the washer's major functions and determine the cause of the problem. This requires the exact model number of the washer for the specific diagnostics activation procedure.
    I performed the diagnostics test and got two codes F22 and F34. All of the switches and LEDs on the control panel seem to be operating.
  • Jahn27
    Jahn27 May 26, 2010
    The F22 fault code indicates door lock error as what you got now. The door lock is malfunctioning; check the connection on the central control unit and the in door lock and assembly itself. Replace the door lock and switch assembly if there's no issue found in the connections.
    There is a manual unlocking tab located at the bottom of the door lock
    and switch assembly. Disconnect power to the washer before accessing it.
    Remove
    the three screws attaching the lower front access panel to the cabinet
    then pull the panel down and off the cabinet. You can prop up the bottom
    front edge of the washer or cushion and lean it against the wall to
    access the screws more easily.
    Reach up along the inside of the
    front panel and locate the bottom of the door lock and switch assembly
    on the right side. Locate the tear-drop shaped tab then gently pull it down until a click
    is heard.
  • Jahn27
    Jahn27 May 26, 2010
    The F34 appears only during a Clean Washer cycle when items are detected in the washer. The Clean Washer cycle is used to keep the washer fresh and clean and the basket must be empty.
  • 11,896 Answers
Press "Pause/Cancel" two times to cancel the cycle. Press "Drain/Spin" if there is water in the tub. Unplug the washer or disconnect power for two minutes, then plug the washer back in or reconnect power.
Posted on May 25, 2010
  • Nate Stansfield
    Nate Stansfield May 26, 2010
    If the washer won't finish a cycle, it probably means that
    your timer
    went bad or stalled. You can take the control panel off and look
    at the contacts for scorching or corrosion or broken wires.
  • Nate Stansfield
    F34 is close inside washer during cleaning cycle. You will have to try and reset the machine again.
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16007803.pdf
Hi, unfortunately, with this symptom it is a bit of a mystery? To assist you with your problem, I have gotten you your service and troubleshooting manual, this is what the engineers use to troubleshoot and effect a repair. Use the troubleshooting procedures and you should soon isolate your problem, and hopefully repair. Also below please find a DIY troubleshooting site to further assist you. http://www.washerhelp.co.uk/diy-repair-help.html
PS: I wonder if the load has become imbalanced? worth a check?
  • 19,396 Answers
Hi.
Check if there is an error code on display. That can help if the problem happens again.
Common error codes are:
F20:Filling/inlet problem.
F21:Drain/pressure switch problems
F22: Door latch failure.
To reset press "Pause/Cancel" button twice. This will cancel the cycle. Afte cancelling the cycle check if there is water in the tub and press "Drain/Spin" to get rid of the water.
After resetting cycle disconnect power cord or trip the circuit breaker to cut power for a couple of minutes and reset the machine.
Regards.
Ginko.
  • Ginko
    Ginko May 26, 2010
    Hi.
    F22 is the door lock. F34 happens when you run a clean cycle with detergent or load inside the machine. Reset the cycle again, disconnect and run a cycle with empty basket.
    Brigadier General:
  • 3,917 Answers
Hi
This is a sure case of a timer mechanism fault. The timer motor is malfunctioning. This is easily fixed by, replacing the timer control module. Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Whirlpool washer will not cut on or run water into it but still will spin out.
Hello, we're sorry to hear about your Washer. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Washer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 08, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet front loader Washer approximately 6 years old. The control lock is on and I can't start the washer. How do I resolve this problem.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet washer problem
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
First, try to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, then proceed with the steps outlined in the link I provided for you.
This is one of the more "involved" error codes that you may need spend some time with. Although, it may NOT be a difficult repair, it still may require some diligence to figure out the cause. I would recommend checking your washer installation for a potential siphoning problem and then check the drain pump as these are the more common causes. If you require additional assistance, please let me know. I hope this helps you.
Jan 04, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Ghw9150pw1 would not start
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
2,093 people viewed this question
Top Washing Machines Experts
