Question about Garden
The pull cord will not engage the flywheel. it pulls our with no resistance.
  • 404 Answers
The rewind ratchet drum has steel balls that engage, they could be stuck with old grease, take it off (reverse threads) and clean it and oil it.
Posted on May 27, 2010
Pull cord won't engage
remove the sparkplug and try to turn the flywheel if it turns freely then the engine is most likely ok. if it does not turn you have a locked engine that means its toast. If it does turn then you have to look closely at th pull recoil that it is engaging the flywheel.
May 04, 2014 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Briggs and Stratton 5hp starter shaft doesn't engage
use the free sign and encourage people to take it
Apr 12, 2017 | Atlas Translator Garden
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
i think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Sep 03, 2012 | Tanaka Commercial Grade "Inspire" Design...
My Husqvarna 128LD pull cord doesn't engage
Possibly the recoil starter pawl's on the inside of the recoil housing not engagning with the flywheel.
Nov 11, 2011 | Husqvarna Garden
When I pull the manual starter cord, it doesn't make the crankshaft turn. What's wrong ?
Check these:
Can you hear the "dogs" engaging in the flywheel when you initially pull on the cord?
If you remove the recoil assembly from the engine then will the rope pull out?
Is something preventing the blade from spinning underneath?
Can you turn the engine over manually by turning the flywheel?
If you remove the spark plug will it turn over?
One of these should help determine the problem. Good luck!
Oct 22, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
I have a Cub Cadet cc4125 string trimmer not starting
need a little more information .. but look for the following .. take out the spark plug and look inside with a flashlight ... if the piston is moving with the rotation of the flywheel then you likely have a blown head gasket .. if there is no compression there wont be a load on the pull cord .. a cracked or damaged piston can also do this .. ... if the piston is not moving when you rotate the flywheel then you likely have a bad "shear key" sometimes called a "shear pin" .. thats usually a half moon shaped small metal part that keeps the flywheel locked rotationally to the crankshaft .. it is designed to shear off if there is an excessive sudden load on the engine .. the flywheel will then spin without turning the crankshaft .. the same thing will happen if you have broken the connecting rod .. (a rod failure is often preceded by lots of clatter from the engine) .. the head gasket or shear key are much more likely to be your problem .. if you cant see in the spark plug hole you might try using a straw to feel the piston motion .. its possible that without the spark plug in place the piston might move even with a bad shear pin .. because with no compression the piston will move freely .. if thats the case you can stop the piston motion with a wood dowell thru the spark plug hole .. if it moves in spite of your dowell resistance then consider the head gasket option ..
Sep 19, 2009 | Garden
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 32cc Line Trimmer pull start will not engage engine.
With a flashlight, look into the area just in front of the pull rope. You'll see the fins on the flywheel. Turn the flywheel with a small screwdriver until you see a bracket mounted on it. There's is one on each side. While holding the flywheel still with another screwdriver, spray penatrating oil on each one and work them back and forth a few times. You'll feel them loosen up. They are spring loaded and should snap back into place. Hope you can understand this. Good luck.
May 25, 2009 | Garden
Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
214 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
