Question about Necchi 3102 Mechanical Sewing Machine
Machine feels like it is bound up neddle will not move
    New Friend:
  • 184 Answers
Normally this will be caused by lint/thread caught in the bobbin/hook area.Remove the bobbin case, push the two fingers (about 4 and 8 oclock positions) that hold the race cover on, and then remove the hook. If it will turn now then your good. Clean the area out, put a couple drops of oil on the hook and reassemble it.
Posted on May 26, 2010
Where can i get my bernina machine repaired in Sri Lanka??
Hi Bernadette, I'm Julie. Where in Sri Lanka are you? Colombo?
Aug 05, 2015 | Bernina Sewing Machines
The bobbin is in its case neddle is threaded still will not sew
What happens when you press the foot pedal? Does the light go on? Does the fabric move?
Jun 10, 2014 | Singer 57815 Mechanical Sewing Machine
Singer Sewing Machine 534 repairs
hi it sounds like the timeing has moved on (1) and also on (2) would need to be seen by dealer.
Apr 09, 2013 | Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
What to do if my machine is out of time
it needs to be retimed at a sewing machine shop
Apr 09, 2012 | Brother CE4000 Computerized Sewing Machine
I have a bernina E65 and it does not move any part ,you hear the motor but the neddle does not work, help? the manual is no help either!!
I assume you have cleaned and oiled the machine as per the owner's manual.I believe this model is belt driven. If so, the belt may have loosened or broken. Replacement is not mentioned in the manual so I feel a tech is needed. My mom's machine used to have a lever that engaged the machine and it wouldn't move with this lever in the up position.
Mar 19, 2012 | Bernina Sewing Machines
Neddle problem
Sounds like the needle is hitting the bobbin casing. Take it out and re-seat it. Check your manual.
Aug 11, 2009 | Necchi 3537 Mechanical Sewing Machine
Neddle screw wont tighten neddle in
There is a small metal rod about 1/2" long that fits into the hold in front of the screw that holds the needle secure. I didn't realize that I had dropped the rod until I could not tighten the needle. I found the rod, put it into the hole and was able to tighen the needle.
Jun 22, 2009 | Brother XL-5130 Mechanical Sewing Machine
Neddle hitting the bobbon
does the hook assembly move when you turn the handwheel? If no, then your hook drive gears are shot.
Jun 07, 2009 | Brother LS-1217 Mechanical Sewing Machine
Centering the starting point
Unfortunately you can't. It is imposible to move the neddle because of the machine limitation. It will only move to the starting point according to your design.
Jun 07, 2007 | Singer CE-200 Quantum Futura Computerized...
Necchi 3102 Mechanical Sewing Machine Logo
99 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
