Compaq Presario 2100U Notebook Logo
Posted on May 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My d-drive will not open. Is there a way to manually open it?
Anonymous
Level 3:
President:
  • Master 2,653 Answers
  • Posted on May 25, 2010
Anonymous
Master
Level 3:
President:
Answers
2653
Questions
Helped
744383
Points
7663
Most optical drives have a pinhole that you can use to manually open the drive.
Here's a guide.
I CAN NOT OPEN MY DELL INSPIRON 15 CD TRAY
Almost all cd and dvd or bluray drives have a manual way of opening. Usually it is a small opening to the right of the button to open the drive. Make sure the system is OFF to try this. Just straighten a paper clip and insert it in the opening and give it a small push. The door should manually slide open.
Hp pavillion wont eject dvd
Turn system off and use a paper clip to manually open the drive door. Straighten a paper clip, then insert it in the small opening to the right of the eject button. This should manually open the door and you can remove any disks in the drive. Then reboot and see if it will open and close normally.
1helpful
Dell xps 2720 dvd drive will not eject cd inside
CD BROKE IN DRIVE - NOW DOOR WILL NOT OPEN
Seems like some of the particles from the broken CD have remained inside. For manually opening up the drive there is a small hole in which you can insert a straightened paper clip. The drive bay will budge a little and you can pull it out manually. Secondly maybe the belt driving the open/close system has gone weak. Try tapping ******* top of the drive right after pushing the eject button. After you have got it opened i suggest you remove the drive from the PC and do a detailed cleanup by completely dismantling the drive.
Disc rom wont open at all and the manual button isnt visible to open it
Most disk drives have a small hole that you can shove a bent paper clip into in order to manually open the drive, which could at least help you recover whatever disk you have in the drive, and may even fix the problem if the drive got jammed. Some computer cases cover up the front of your drive however, so you may need to open up the case to get at the drive.
I have a DVD in my SD 3990SU - it won't play and the door won't open using the remote or the button on the front of the unit. is there an alternate way to manually open the cd loader.
You will need to open the set and manually move the motor drive to manually shift the drive to release the Cd.
Now check the voltage to the drive and also check the power, the main board drive circuit, the motor .Check the control signals to the motor drive , if absent the processsor control is faulty.If present the drive IC is faulty
1helpful
3answers
If it hasn't opened since 2010, may dennythedon2003 spammer expert will finish English classes in his country and be able to help.
You can manually open the DVD drive by inserting a strsighten paper clip into a tiny hole just beleow the drive tray. Push the paper clip into this hole gently and the tray will pop out slightly, then grab the tray and pull it out until the tray is in the fully opened position.
2answers
How to manually open drive door I have a mad dog MD-16XDVD9A4 drive. Stuff got caught when the drive door closed (nearby plant) and now I can't open the door to remove debris. Any way I can manually open...
Turn the computer off and find a large paper clip. straighten the clip and there should be a very small hole below the drive tray. Push the clip into the hole and it will manually open the door.
9helpful
The cd drive won't open on the tower
If you look closeley there should be a small hole near the eject button. You can manually open the door with a straightened paper clip.
Cd drive opening and closing on its own
You never should have pried it open. Only use the manual eject pin-hole with a paperclip. Noe it seems the drive tray is damaged and will not close properly so it is constantly opening and closing trying to find home. The drive will need replaced.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
