Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M40X
Hi, I have a Satellite M40X. Once in a while, It used to shutdown by itself when the base of the laptop becomes very hot. So I opened it and cleaned the fan and heatsink area. This fixed the issue and worked fine without any problems for 2 months.
Now all of a sudden it died while playing a DVD and won't powerup. When I tried to turn it on nothing happens, after couple of attempts only the the fan is turning on. No Hard Drive light.
I did some basic checks Power and Battery is O.K. Hard drive is O.K. I suspect the problem with motherboard but don't know how and what to fix. I appreciate your valuable help and suggestions-- Thanks in adavance.
  • Srini_Reddy Apr 29, 2008
    Hi, I tried booting with and without battery, Still the problem persists.
    Genius:
  • 1,554 Answers
Try booting without the battery installed.
Posted on Apr 14, 2008
  • Karl Whisenand
    Karl Whisenand Apr 29, 2008
    well it looks like the mb has power issues now.
    it might have blown the regulators or just the cpu is gone bad.
    it will be hard to determine without swapping out parts at this point.
    cpu's are cheap if it has a removable cpu,
    they go for 10 to 25 on ebay. the cpu is not likely the issue though.
    mb's are pricey and I don't see any for sale anywhere.
    there are about 10 over heated transistors on Mb that would be suspect in this issue likely one or more gave up and died.
    you will have to wait for a MB or send it to a repair center that specializes in toshiba.
SOURCE:
How do I unlock my scroll lock on my toshiba m40x
Reboot to access Bios, Select F7 to reset all to default. There is a separate option in Bios to unlock scroll lock.
Oct 16, 2012 | Toshiba Satellite M40X-114 M40X-118...
WHATS HAPPEN MY TOSHIBA SATELLITE A300-14S LAPTOP BATTERY NOT CHARGING THEN WHEN I REMOVE BATTERY PLUG DIRECT DC IF HOT AUTOMATIC SHUT DOWN
the laptop cannot ventilate the hot air out.may be a lot of dust covered the cpu fan.go to any service centre and get it cleaned.if you can do it yourself then its fine.it is becoming too hot and is shutting down.
Apr 05, 2012 | Toshiba Computers & Internet
I want to change the CPU fan in my Toshiba Satellite M40X
I found an awesome site
I found the service manual for the Toshiba Satellite M40X in PDF format
You want chapter 4 replacing the cooling module.
http://tim.id.au/laptops/toshiba/satellite%20m40%20tecra%20a4%20dynabook%20vx4.pdf
Nov 10, 2009 | Toshiba Satellite M40-S417TD Notebook
No boot up on my Toshiba Satellite M40X laptop!
try to clean the memory the bronse pin use dry clothes or pencil eraser then put it back, if encounter same error maybe got problem with flex cable come from motherboard go to lcd panel
Aug 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite M40X
HI,
What happened..hmm.. so your problem is not yet solved.Actually i was about to take your chat but unfortunately someone else took it.
I hope he can help you..
Or else please let me know..
Apr 21, 2008 | Toshiba Satellite M40-S417TD Notebook
Replace toshiba satellite m40x (z008) 60GB toshiba HD with a Samsung HM160JC 160GB HD
both HDs must be either sata or ide and each one must not have a password lock.
good luck
Dec 14, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
188 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
