Question about Craftsman Gas Mini - Tiller/Edger
I have a two cycles craftmans gas mini tiller and while i was using it the other day it just shut off and now it want start back
  • 1,339 Answers
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
2-cycle gas mini tiller
check the spark plug. take the spark plug out and put just a dab of gas where it goes and put it back in then try starting it. i have the same problem with mine
Jun 29, 2012 | Craftsman Garden
Tiller will not continue to run. It has good spark. It will start if primed through the carburator but once the prime burns off it dies.
If fuel sits in the gas tank 3 months, the fuel deteriorates and it gums up the filter in the tank. You need to put stabil in the tank. This has happened to me over and over. It is best to dump out the gasoline if you don't use the tiller within one month. Some people who use chain saws commercially dump all the gas out every day and start over the next day. The symptoms are the tiller won't run at high speed at first, then as it gums up more
it won't run even at low speed, then becomes hard to start.
The gum is hard to see. Pull out the gas line to get to the filter and change the filter. Filters are only 3 or 4 dollars at hardware stores.
Jun 01, 2012 | Honda 25cc 4-cycle Mini Tiller
I have a craftman 4 cycle mini tiller, running to slow. need to run at a faster speed. do not where to adjust.
If the carb has the "fixed" throttle control. Find the governor control lever with the small, long coiled spring attatched to it in the middle. It may be hooked to a metal tab that is on the back carburetor bolt. Bend the tab to your left to increase set speed or to the right (towards governor lever) to decrease.
Sep 05, 2011 | Craftsman Gas Mini - Tiller/Edger
Honda 4 cycle cult wont start. New gas primer primes new spark plug. Won't fire.
Check the start switch and the start switch line. If not broken, check the choke switch and try different settings to start it. Last check the gas line for any cracks. This tiller can be easily be flooded when pushing the prime button..
Jun 25, 2010 | Honda 25cc 4-cycle Mini Tiller
I have a mantis 2 cycle tiller. it starts and runs for a minute then shuts off.
do a fuel system overhaul...but always w a 2 stroke pull the muffler and inspect the piston and cylinder if its not scored and you feel good compresion most likley its your fuel system. if it is scored it gets metal to metal and the hot metals expand.
Jun 22, 2010 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I need to find out gas to oil ratio on 6.5 hp craftsman lawn mowe
This info is available at any dealer or repair shop. I would recommend contacting them to be sure. The lead says mini-tiller but your question says lawn mower. The 6.5hp motors, as far as I've dealt with were 4 stroke which means no mixture, but check with a dealer or shop, they'll know.
Apr 21, 2010 | Craftsman Gas Mini - Tiller/Edger
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman Gas Mini - Tiller/Edger Logo
229 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
