Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Cabinet flanges and mullion very hot to the touch and not cooling at all, model ed25qf
    Novelist:
  • 77 Answers
Turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
Posted on May 30, 2010
My Admiral mullion is hot
Probably the defrost element has failed, ice & frost will continue to build up & it's ability to cool will deminish over time. Has to be checked & possibly replaced.
Nov 20, 2013 | Admiral Refrigerators
What does it mean when the section between the freezer and refrigerator on a side by side unit is hot to the touch?
It means the mullion heater is working. The strip between the doors is called the "Mullion" on "Kitchen Aid" this is part of the refrigeration system. Known as a "Yoder Loop".
Aug 18, 2011 | KitchenAid Superba Architect KSCS25INSS...
Our fridge model has the freezer on the bottom. When the fridge door is open, the front of the fridge above the freezer compartment is hot to the touch - also had a one time incident where the...
It is normal for the strip between the freezer and fresh food compartments to be warm to the touch. It's called the mullion strip and uses gas from the compressor discharge line to prevent moisture from forming there. Older models used an electric heater to do the same thing.
As far as the one time operational failure......it's a bit difficult to even guess not knowing the brand and model. Talk to us if it fails again.
Aug 20, 2009 | Refrigerators
Whirlpool Gold side by side cabinet extremely hot to the touch.
the refrigerator has mullions simaler to the veins underneath your skin to aid in cooling .the first thing to check is the fan by the compressor is it running while the compressor is if so the next thing to inspect is the condensor coils usaly underneath the fridge or directly on the back of the fridge alot of times these get clogged with lint and or animal hairsimply unplug the fridge and gently brush off the lint and vacume.your feed back on the resolve for this issue would be gratly app.
Aug 13, 2009 | Refrigerators
Hot center strip
when the center mullion is hot then it means your units condensor fan motor is out. the fan is located by the compressor. this fan keeps the condensor coils cooled off. if the fan is not running then the unit vents through the cabinet.
Jun 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
The dividing wall between the freezer compartment and refrigerator compartmant is very hot to the touch , use to be warm now almost to hot to touch. mod. #106.56539400
the condensor fan by the compressor is not running. this fan cools the compressor and condensor coils. if it does not run then the mullion (center between frzr and refrigerator side) gets very hot
Jun 24, 2009 | Refrigerators
The middle divider heats up
Yes it is normal. Old side by sides had an electric heater through that strip known as the mullion that you could turn off with the "energy saver" switch. Not any more... it is now that last pass of the condenser that runs around the door to prevent moisture build up. The more load on the sealed system, the hotter the mullion. If it gets almost too hot to touch, clean the condenser coils as they are probably getting plugged with lint and can't evacuate heat anymore... cooling will suffer too if that's the case not to mention higher energy consumption.
Dec 18, 2008 | Kenmore Refrigerators
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer working but refigerator not...
Mullion heater is not the problem. If the refrigerator is not cooling look to the freezer compartment for your problem. Air from the freezer is used to cool the refrigerator(s) section. If the freezer coil frosts up it stops air circulation to the rest of the system. Although you may think the freezer is working properly it may have a defrost problem and will show up there also. Look for signs of frost on the back wall of the freezer as a sign of the coil freezing. The mullion heater is designed to put out just enough heat to stop condensation between the outside temperatures and the inner compartmant temperatures. If the inner compartment is warm the heater will seem warmer than normal.
Jun 26, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
181 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
