Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
    Problem Solver:
  • 18 Answers
There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
The sheet feeder on top.
If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
The paper feeder.
A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
Posted on Jun 28, 2010
    Sergeant:
  • 284 Answers
Most probably is something stuck at the paper feeding area or FEEDER ASSY faulty.
Posted on May 26, 2010
Paper feeds incorrectly the feeder is pulling to the left and causing the paper to jam or to tear.
Sometimes dried ink on the roller causes it to incorrectly "grip" the paper, making it slip in one section and pull to the side, Check the rollers for Ink and other dirt.
Also try less paper in the feeder, it may simply be too much and is not able to feed it correctly.
Hope this helps GM
Apr 10, 2011 | Canon PIXMA MP470 All-in-One Printer
The paper won't feed and the paper jam light goes
Wich copier model do you using?
My wild ques would be paper feed rollers. Try to clean them with alcohol and try to copy.
But still I would want to know the model.
You can also contact me on emma.servis@gmail.com, if its Canon copier.
Jul 17, 2010 | Canon Office Equipment & Supplies
The paper in my canon 2270 is sticking every time it feeds. This only occured after we ran some books
Make sure the paper size dial is set correctly for size and orientation of paper loaded (on the front right corner of the paper tray). The copier will display paper jam every time if this dial is incorrectly set. After this has been confirmed, if it still jams, try cleaning the paper feed rollers with soapy water or isopropyl alcohol (make sure rollers are dry before attempting to copy again) Let me know, please
Oct 25, 2009 | Office Equipment & Supplies
Not printing envelopes and printer locks up
Use a small flash light and check for any debris blocking the roller from the tray...
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
The paper will not feed correctly. The Right side is getting jam
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
Feb 02, 2009 | Canon PIXMA MX310 All-In-One Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Paper jam
One of your jam sensors may be stuck in the actuated position by a paper scrap or dust, giving a jam code to your printer. There are usually two sensors, one where the paper feeds, and one where the paper exits. Try this: hand-feed a sheet of paper through the machines paper path,IN THE DIRECTION THE PAPER NORMALLY FEEDS. This may force out whatever is actuating the sensors.
Aug 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
The paper feed wont stop
the paper picking rollers i think r weak try cleaning the rollers n try it again.
thank u
May 26, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Canon MP730 not feeding properly.
The machine had never given trouble before, only this time when a new person was using it. So, figuring they may have refilled the paper tray incorrectly, I took out the paper guides at the back and kept hand feeding one sheet at a time. After each jam up I had to reset everything but after about 7-8 tries "something" cleared and now it works fine.
Regards BB
May 22, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
354 people viewed this question
old marine
old marine
