Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
ML900wTW transformer gets stuck at the "on" position and stays there. Lights wont come on,unless I advance the wheel manualy. Then the clip will turn the lights on. The lights have no problem turning offautomaticaly. Do I need a new red "On" clip? If so, Where do I get it? Transformer is 6 yrs old.
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
http://www.fixya.com/support/r8391011-power_pack_not_working
Posted on Feb 27, 2011
Emergency brake might be stuck on my 95 nissan pick up truck 2 wheel drive. My turn signals wont work and neither do my hazards. Brake lights wont turn off unless I pull the fuse out
Check for a faulty switch at the brake pedal, sounds like the contacts are welded shut or hot wire grounding out someplace in the circuit.
Aug 08, 2014 | Cars & Trucks
Hummer H3. Wont shift out of park, key is stuck in ignition, will not turn on accessories or crank, break lights stay on. Removed interior carpet to apply herculiner. Any ideas as to what the problem
Many cars, I presume the Hummer also will not let you shift out of Park unless the Brake pedal is depressed. Most do this by an electronic interlock with the brake light switch. Yours is broke. Either the brake light switch has moved out of position or is defective, or your brake pedal is not retracting to the full off position.
Mar 30, 2014 | 2007 Hummer H3X
Steering wheel stuck and key wont turn
One of the things is a lock-out switch on the brake pedal lever. Some are coordinated with the gearshift, the Keyswitch, and the starter Relay. Check to see if the brake lights work when you press on the brake pedal. If no signal is going to the brake lights, then there is a chance that the Park shift lever, the steering wheel and the Keyswitch are bound up.
Sometimes a steering wheel is at the extreme reach of the travel in the front suspension. This can sometimes happen in cold weather when the car is sitting on ice or snow. When the ice or snow melts, the front tires settle into a position that puts pressure on the steering wheel and loads Torque up the steering column. Another possibility is that the car was bumped in the Parking lot and jammed into a position creating Torque on the steering column.
Last, the tumbler inside the Keyswitch could have fallen apart and that is why the mechanism is not releasing the steering wheel.
There are adjustments in the Keyswitch to be at the correct position to work with the lockout at the bottom of the steering column.
Jan 21, 2014 | 1999 Mercury Grand Marquis
Hey Guys, need some crazy help ! So here`s the deal, i have a accent 1996 5 doors, and my turn signals and brakelights ( as in not when i press the pedal , but when they are just on for the night ) and...
Turn signal are not meant to stay on. Brake lights only come on when you press the brake pedal.Then you have tail lights that are totally different from brake and signals light.they are for night use.
Feb 11, 2011 | 2000 Hyundai Accent
The light is staying on the cruise control. Its staying activated all the time unless I unplug the battery.
If the cruise control functions on the steering wheel are working ok, press the switch (where the light is located) a few times to see if it is stuck in the ON position. If this is the case, and wont return to OFF, replace the switch.
Jan 06, 2011 | 1998 Honda Accord
Tiburon 04, left turn signal lights stay on once activated by either turn switch, hazard light switch, or alarm. Can sometimes get them to go out by using right turn switch position, or playing with hazard...
replace the turn signal 'Clicker' also known as the turn signal relay. Most likely the problem unless you have a really wierd electical issue that will be hard to isolate...
Peace,
Jan 23, 2010 | 2004 Hyundai Tiburon
Coil is freezing, stops cooling, no water at despencer. turn timer knob manualy and it does shut off and back on again. defrost timer or heater?
depends on the brand, most likely the defrost thermostat.
heaters rarely go bad, timers usually will not advance causing the coil to frost over.
if you turn the timer to the "defrost" position and wait for 20 minutes. after a couple of minutes it should have the heater get hot and then frost should drip onto the heater and make a "hissing" or "sizzling" sound. if it does make these sound, then replace the timer.
Dec 31, 2009 | Refrigerators
My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 20, 2009 | Intermatic Malibu 300W Power Pack...
The interior lights will not turn off they stay on the only time they turn off is when i start the jeep,i have checked everything i can think of but can not get the interior lights to turn off any...
It sounds like you have a stuck door switch -- these turn on the lights when you open the door.
I'm guessing that the lights turn off when you start the car because the battery is pulling down the current available to the lights.
Apr 28, 2009 | 1998 Jeep Grand Cherokee
2000 gmc jimmy stuck in 4 lo
i found the problem it was the acuator on the side of transfer case so i took it off and manualy put it in 2 wheel drive now all i have to do is get under there and turn it with a tire iron thanks but got it under control......
Nov 30, 2008 | 2000 GMC Jimmy
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
192 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
