Question about Bosch 24 in. SHU43 Built-in Dishwasher
DISHWASHER COMPLETELY DEAD
I have pressed the start button on the dishwasher, but nothing happened. No lights came on, no sound at all- completely dead. The model is a Bosch Exxcel. I've changed the fuse in the plug, but made no difference. There seemed to be a large amount of greasy water sitting in the bottom of the washer.
  • Bosch Master
  • 2,605 Answers
Hi John, and welcome to Fixya. I don't believe the greasy water sitting in the machine has anything to do with the problem, rather it is likely a by-product of the problem. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Posted on May 25, 2010
Testimonial: "Thanks for the solution. I'm afraid I am not very technical and some of what you've suggested is over my head. I'll pass the info to my brother in law to decipher and see if the problem can be sorted"
Power to the on/off switch OK. Press on and nothing happens
Posted on Jul 15, 2010
Dishwasher won't start.
If it won't complete diagnostics, replace the main control Help Me Find My Model Number RepairClinic com
Jul 26, 2016 | KitchenAid Dishwashers
My Maytag dishwasher will not run. It is completely dead. Nothing lights up, etc. It is only a few years old.
Many newer dishwashers are wired to a switch on the wall as a means of service
disconnects in new homes. Also I would check the GFCI outlets in the kitchen area
and possibly the bathroom as well to see if they are tripped. (Press the test button and
then the reset button on them to test). The next thing I would check is the breaker
panel to see if the dishwasher is on it's own breaker. And lastly I would check the
connections to the dishwasher itself (after making absolutely sure power is off to the
wiring feeding the dishwasher at the breaker panel). I hope this is helpful.
Aug 06, 2011 | Maytag Dishwashers
My dishwasher has stop running and I need help!
If it is completely dead and no lights or sounds it may be the thermal fuse. I have some instructions here that might help. Follow this link and let me know if it helps.
Dead Dishwasher
May 22, 2010 | KitchenAid 24 in. KUDS01ILWH Built-in...
Bosch SHX99A15UC went completely dead. Circuit
no it wouldn't, this is a common failure on bosch dishwashers. you have either a bad control or a bad touch membrane. parts are fairly expensive and only way to know for sure is to replace one. I usually find that the control panel is at fault most times
Apr 23, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
My dishwasher will not start. The 3 second button light is on and when I press it nothing happens . I try pressing any other button and nothing works
It sounds like you have "locked" the dishwasher. This was an added feature that most people never wanted since it only seems to be set by accident.
Try pressing the 3 second button and holding it down for at least three seconds. This should turn the light off. Drove us nuts the first time it happened. If it doesn't turn off then I guess it is broken.
Jan 03, 2010 | Maytag MDB7100AWB Dishwasher
My Trionr XL dishwasher will not run. I push the
It sounds like your dishwasher might be locked. You unlock the dishwasher by pressing the "heated dry" button for three secs. and then releasing it, that should do it.
Jul 04, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Press START and nothing happens
yes the door has a safety switch that will keep the machine from starting, this is most likely the problem.
Aug 12, 2008 | Kenmore 15762 Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kitchen aid dishwasher KUDK01ILBS1
The heating element looks like a big metal pipe and located on machine's bottom (not inside the cabin). Good luck !
Jun 05, 2007 | KitchenAid 24 in. KUDK02CR Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
641 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
