Question about Brother MFC 210C All-In-One InkJet Printer
Printer says black, cyan etc near empty
Hi, I refill my carts and have probably confused the print counter when refilling. However, your trick of unplugging the machine(brother MFC5440cn) taking out the carts and leave for 3 mins, has not worked. Having unplugged the machine, taken out the carts and then left the machine for at least 3 minsa, then plugged back in, the display, did not ask for carts but said each colour was now near empty, and this with no carts installed! Any ideas please.
Regards
Chris
  • 832 Answers
Open scanner. take carts out. refill to max and place it back in one after another. Watch display and give answer.
Posted on Apr 07, 2008
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Minolta 2430dl, cyan, magenta, and yellow toner cartridges all show empty. Black shows 42% remaining. How do I get printer to print?
Some printers will refuse to print _anything_, until you replace/refill _all_ of the empty toner cartridges. So, replace/refill.
Dec 30, 2009 | Konica Minolta Office Equipment & Supplies
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Pixma mp460
Check the labels are near the top straight lugs and not near the curved lug and there is nothing covering the indent near the curved lug. If they are to low down it will block the signal from the chip to printer.
Jun 08, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Is there a way to get Brother MFC-240C to only use black ink cartridge?
Theres a simple trick to cheat the machine.
BUT
you will definitly destroy the printhead when doing so for a longer periode!
You have to put some black adhesive tape around the middle part where you can see this black palstic flag inside the cart. This flag signals the printer that the cart is insert and later on when the ink is down to give the waring: near empty.
I do give you the advice to do another but saver cheating:
You can refill the cart with a mixture of 8 ml destill water and 3ml 85%-Glycerol (e. g. Glycerin alc. which can be bought at a drugstore for a few cents). Shake the mixture well (within the syringe) before refilling the cart.
See pics here how to do so (LC1000):
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
(brother has changed the construction of the carts! If you can see a plastic quad in the middle of the cart, you have to drill the hole just behind the air valve (white plastic looking out of the cart)
Feb 24, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-420CN All-In-One
unplug maqchine from power. take all carts out. wait 5 minutes. connect machine to power. insert carts as demanded. give the right answer if machine asks if the carts are changed. machine will do some cleaning.
do you use generic ink? in that case you might have clogged the printhead with wrong ink. The ph cant be cleaned anymore.
nevertheless try this (carts should be nearly full!):
press menue then start mono (blue copy) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4. Machine will display init_all. press start mono. machine will refill tubes and
ph with fresh ink and do some cleaning. after that press 7 then 6 then 3 and start mono. machine will do a powerpurge.
press zero then 9 to do a quality test print. If it cant do the job leave maintenance by pressing 9 then 9. do the test print manually by pressing ink etc.
If you still do not see any colors the ph is clogged and cant be fixed anymore. It has to be replaced.
Dec 03, 2007 | Brother MFC 420CN All-In-One InkJet...
MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Lexmark X2550 Cartridge Refilling
I just ordered a Lexmark X5495. The carts that come with it are throw aways (or return them to Lexmark to be remaned.) You can use cart. # 28a, 29a, 34 or 35 to refill, the latter two being the high yield carts. And yes the printer manufacturers are playing a cat and mouse game with us. I normally use Epson because it's easier to circumvent the tricks they employ. I understand Canon is an inexpensive printer to run also. HP and Lexmark are the costliest products to operate. There is a utility for Epson called SSC ver. 4.30 that gets around the safeguards by resetting the cart. chips and a whole lot more. Someone needs to write a utility for HP and Lexmark to replace the standard driver/ink monitors that are designed to siphon off our wallets quicker than they do ink. One more trick I've heard: when the printer is looking for a new cart have a spare cart handy and put it in in the printer. The printer will now think you have ink in the cart.(whether its empty or full) Now trying swapping it out for a refilled cart and see if that works. The point is this: the printer wants to see a new cart serial# ,not the same one that was just being used last.
Oct 29, 2007 | Lexmark X5495 Printer
Near empty yellow
Do print until the message EMPTY (Printer stopps printing). DO NOT refill or change cart when message is shown: NEAR EMPTY! You fool the printers logic. Machine counts down the rest of the ink in the cart. When you refill at that moment the counter is disoriented! To clear the counter: Unplug powercord. Take carts out. Wait 3 min. Plug in power. Machine demands carts. Do use carts at full level (refill before you put them in). Works normal afterwards.
Sep 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
112 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
