Question about Danby DPAC8020 Air Conditioner
P1 error on everstar mpk10cr and comprossor wont turn
Please help me unlock control panel so i can try and clear error message
Thank you for the information!! Basically hit the TV like in the old days. Mine is icecapping my garage workshop thanks to you. I was lost in the weeds with tech stuff I knew was not the problem. Saved from miserable shop conditions in the deep south dirty thanks to you.
Posted on May 25, 2016
  • 8,197 Answers
On the MPK-10CR, this code shows up (for me) when either the bucket for evaporation collection isn't in the compartment, or it isn't seated properly. Try re-seating it a few times until you hear the A/C kick in.
You can get the manual on the link below if you need it.
http://www.supportuscenter.com/documents/MPK_Manual.pdf
Good luck
Posted on May 25, 2010
    Problem Solver:
  • 4 Answers
You should here a click to ensure the water bucket (container) is properly engaged
Posted on Jul 14, 2010
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Everstar mpm 08cr bb4 manual
Try Googling (Everstar)(mpm 08cr bb4)(manual) without parens.
Oct 23, 2017 | Everstar Portable Air Conditioner Everstar
Everstar mpk 10 cr 1 manual, have an error code of P-1
It means that the little drawer for the water on the side is full of water or that it is not closed completly. In the water drawer there is a switch that makes it turn off the AC if it is running ,then it will give you a P1 code.
Make sure the water drawer is empty of water then. put the drawer back in carefully and gently, the switch that is built into the drawer will make contacts and your problem should go away. you might have to unplug the unit from the wall for it to clear the problem after doing the above steps.
Also here is a link to their site, Midea the company that makes these MPK-10CR units. For the owners manuel http://www.supportuscenter.com/documents/MPK_Manual.pdf
http://www.supportuscenter.com/pilot.asp
Sep 11, 2009 | Everstar Portable Heater/Fan
New air conditioner not working P1 error
Check float for drain pan is not taped up for shipping, and remove whatever is holding it up & let it drop down, into pan.
Jul 26, 2009 | Heating & Cooling
My Everstar mpm-08cr-bb4 stopped working and dislays P1
The P1 code means the lower water bowl is full.
Put a pan under it an pull the lower plug (some 10" below the upper drain plug that I hope you have a hose attached to.
Jul 07, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
My unit has a P1 error and has stopped
Pull out the water container. Make sure the black floater switch is not stuck or impedes from working properly. If this doesn't work, need to look at replacing this
Jun 25, 2009 | Heating & Cooling
Need manual for EVERSTAR model MPM1-10CR-BB6 air conditioner
This site has the manual. It doesn't state the same model, but it's the same manual.
http://www.supportuscenter.com/product.asp?specific=90
May 17, 2009 | Heating & Cooling
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
Everstar air conditioner
My Everstar Portable Air Conditioner, Model# MPM-08CR-BB4 will not work. The only thing that works is the "P1" light. Please help!!!
Jun 09, 2008 | Office Equipment & Supplies
Danby DPAC8020 Air Conditioner Logo
778 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
