Question about Fisher and Paykel GWL11 Top Load Washer
My GWL11 top load washer just stopped working and keeps resetting the circuit breaker. Any ideas what is wrong ? How to fix it ? Thank you.
  • 159 Answers
Could be many things,is the machine leaking water on floor,if so water could be leaking onto electrical parts underneath such as the pump or through the motor.The tub seal could be leaking or the pump could be leaking.thats all i can think of given the limited information.
Posted on May 29, 2010
How to reset washingmachine
Unplug it for a few minutes or turn power off at the breaker box. Plug it back in or reset the breaker.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machine Pops GFI Circuit
I agree. could be heater or motor..try disconnecting one wire on heater then trying if still same try unplugging motor plug ...this will say which one..please leave feedback..
Apr 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Apr 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Our washing machine keep appear E-90 what is wrong with it ?
AFTER UNPLUGGING THE WASHER TRY THIS, E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by resetting, cleaning the connectors make sure the connectors and the circuit are dry.
Mar 13, 2009 | Zanussi ZWF1440 Front Load Washer
Kenmore top load washing maching tripping the breaker
the breaker is likely worn out, have that checked by service person first, then check that machine does not need to be lubed etc. for too high a load on the circuit.
Feb 09, 2009 | Kenmore 15864/15862 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
136 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
