Panasonic PT-47WXC43 47" Rear Projection Television Logo
Anonymous Posted on May 25, 2010
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on May 25, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955292
Points
33084
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
1helpful
My tv has a arching green tint towards the bottom of the screen that also gives off a double image. I have a Panasonic hdtv 47 in screen model no: PT-47wx54j
Convergence problems. If they can't be fixed from the setting on the menu then the convergence board's IC's are faulty and must be replaced. This is a job for someone who has some electronics experience.
2helpful
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
Curved double image at bottom of TV and looks like a 3d image
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Purple and Green haze on television image
Do you have any speakers near the TV, that aren't shielded... ?That's kinda what it sounds like to me.
Green and purple band of color
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
*Screen Looks 3-D
*Colors wont align
Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Green....purple....colors
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
4helpful
Panasonic Model No. PT-47WX42F
Replace the convergence amps. That unit takes two Sanyo STK392-110 and you could use 150's for greater reliability. Also replace one or more of the 1.2 ohm resistors in the yoke return circuit out front of the amps.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
