Question about Sony Cyber-Shot DSC-T5 Digital Camera
The Flash seems to have stopped working - what are my options
I double checked setting to verify I'm not in a "no-flash" or somesuch - working well one day - then nada the next. Changed up all batteries and verified charging on each. It isn't the battery. I've also reset or re-initialized the camera. Assuming I need to replace it - what's the impact?
  • Sony Master
  • 4,924 Answers
The impact ...hmm there is nothing much ..if you are sure that this is not a issue of modes..or any other manual setting that will not default itself by the digital reset ..(some cameras have mode changer as a switch that only manually can be made..and have a no flash mode)
and if you are 110 % positive that it needs replacing ..the issue is to find one that fits..cause you may not find the exact model .for that you should open it and see the model ..(id number ) and look for specifications ..on the internet and either locate one similar on a camera parts site ..or on the manufacturer site an original one ..or buy a similar specs one ..and fit it in place ..If it will use the same power and about the same kind...to fit in place ..will work ..
Also when you open it ..take a good look cause it may be an issue of loose contact or something and the actual flash to be functional..
Posted on May 25, 2010
  • davepayne421 May 26, 2010
    Is there a series of steps to force a flash, to double check my assumptions? I'd hate to bypass a step just because I think I'm competent. :-)
  • Catalin Turcu
    Catalin Turcu May 26, 2010
    to be sure that it is not a setting issue ..try to reset to factory ...look in the manu cause all cameras have this feature ..There is a possibility to have a manual mode that do not support flash ..and the camera to be ok ..so ..try to reset ..and if it has switches that can not be digitally reset from the function ...put them to normal mode...I mean there are some kinda cameras that still have manually change for modes..in the classic way ..
    if this isnt the case..just reset ..and after that look in the main menu on the shooting mode to see if the flash is activated..(flash on ) Probably will be a common on screen menu with arrow navigation and when you get to flash ..point to flash always on ...or flash on ..and click select or ok ..
    if the feature indicates flash on ..and it will not work ..only than you can say for sure its dead..
I cant log in
1. The date on your computer needs to be set properly -- double click the clock verify that
the time and date are set.
2. If your password information is not saved, verify that you are typing it in with the
correct case (uppercase or lowercase).
3. Change your password to something smaller (under 10-12 characters), then try signing in again.
4. If you use a firewall (like ZoneAlarm, Norton Internet Security,WindowsFirewall etc. ), it's possible
that Messenger doesn't have the correct rights to access the Internet, especially since you
upgraded. You may need to re/add Messenger to the allowed list of programs in your firewall
if this is the case.
5. If you disabled your firewall in the past, it still may be blocking Messenger -- try
restarting it and see if that helps the situation. You also might try uninstalling an
installed firewall, to verify that it isn't causing a problem (even if it is disabled).
6. Clear your IE cache and cookies -- open Internet Explorer, click the Tools menu, then
Internet Options, then click the Delete Files button, and when that's complete click the
Delete Cookies button.
7. Check your IE Security settings -- open Internet Explorer, click the Tools menu, then
Internet Options, then Advanced tab, scroll to the Security section, and verify that "Check
for server certificate revocation" is unchecked. Also verify that 'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here.
http://www.adobe.com/support/flashplayer...
Jun 13, 2011 | Yahoo Messenger
My sony flash memory is showing in accessible pls help
There is a way to make it not inaccessible but that would require you to reformat it using the steps below:..
1. To verify that the USB flash drive is actually the cause of the problem by inserting the drive into a USB port on a different computer. Check to see if the drive remains inaccessible on the separate computer drive. Plug the USB flash drive back into the original USB port if it still shows up as inaccessible.
2. Please open the computer's Start menu and then click on the "My Computer" button to bring up a new window with a list of the drives connected to the PC. Find the "Map A Network Drive" button at the top of the new window. Click on the button and wait for another window to pop up on the screen.
3. Now click on the "Drive Letter" drop-down menu at the top left side of the window. Select a drive letter that you want to use for the USB flash drive. Click on the "Browse" button and then locate the USB flash drive. Click on the drive and then click on the "Open" button. Click on the "Finish" button and then restart the computer.
4. Please return to the Start menu and then open the Control Panel. Double-click the icon in the window labeled as "Administrative Tools." Scroll down through the new list of options that will populate the window and then double-click the "Computer Management" link. Click on "Allow" if your computer's operating system asks for your permission to open the Computer Management menu.
5. Find the "Storage" button at the left side of the window and click on it to bring up a new list of options. Click on the option labeled as "Disk Management" and wait for the list of attached disk drives to populate the panel at the middle of the window.
6. Right-click on the drive letter you selected earlier when you mapped the USB flash drive to the computer. Click on the menu option labeled "Format." Make sure that the "File System" heading is set to "NTFS" and then click on "Start" to reformat the drive. Volia.
7. Restart your computer once the reformatting process has completely finished. Attempt to use the USB flash drive again. If still no luck, try purchasing an entirely new flash drive if the computer still will not recognize the drive, as that will indicate it is defective or physically damaged somehow.
Mar 20, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
M8800 camera flash stopped working.
I have this same problem, when you switch the camera function on it doesnt even give you the option to turn the flash on as the option is greyed out. I think it is an error in manufacturing and something you can't fix :(
Jul 03, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Polaroid i733 always double flashes
Sorry - why is it a problem ? Are the photos OK ? If so, don't worry
Jun 11, 2017 | Polaroid i733LP Digital Camera
When i try to log on to messenger it doesn't seem to connect. I just have the timer going around and around. can you please help!
here are things to check or try;
1. The date on your computer needs to be set properly -- double click the clock verify that the time and date are set.
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
go to control panel,click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save. until your problems are solved you can log on here http://iloveim.com or http://webmessenger.com
Dec 10, 2008 | Yahoo Messenger
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Flash
Did you try to reinitialize? Setup menu go down to the third Setup#1 menu and make sure you click OK to reinitialize. That's what the manual said.
Apr 28, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot DSC-T5 Digital Camera Logo
29 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
