Question about Royal 85X Shredder
Royal 85x crosscut shredder stopped working
Royal 85x crosscut shredder, worked fine until 2 days ago when we cut up two Credit cards. Yesterday wanted to shred a few papers, light for regular operation turns on (Green) when switch is in forward/on position. When paper is inserted one hears a clicking sound when 'light barrier' in slot detects the paper, but nothing happens. Reverse, top position of the switch, typically turned the light on and the motor in 'permanent'/un-clog on position, neiter happen now, light's not on nor does the motor run. Unplugged the unit and left sitting for a day to no avail. Just took the motor/cutter unit off, removed bunch of debries in the motor/cutter compartment after unscrewing it. Nothing obvious such as pieces broken off or 'stuck' paper. - Should the cutting rolls move, or how can one move them to check areas not easily visible for stuck material? Especially credit card plastic pieces I suppose could lock it up, no?
  • Anonymous Mar 12, 2014
    When basket is removed indicator light goes on.
    Problem Solver:
  • 19 Answers
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
Posted on May 30, 2010
  • buysellgb Jan 23, 2011
    DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
    We have 15 years developing experiences and will implement the advanced products to our customer.
    Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
    * Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
    * Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
    * Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
    70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
When trying to use the 160MX crosscut paper shredder, when you insert a piece of paper it starts to go in then stops. If you hit reverse the paper comes back and the edge is cut up. The motor sounds...
Try putting some "shredder" oil onto the cutting blades...they should be lubricated routinely and if they have never been oiled they just may be plugged up with paper dust and debris.
Feb 23, 2011 | Royal 160MX Shredder
My royal shredder will shred paper just fine but now it won't shred a credit card. any ideas?
Silly question if it shreds paper fine but....when did you last oil the machine.???
Cross cut shredders need to be regularly oiled..( pour some shredder oil across the cutting blades).
It may just be that the credit card is too thick!
Jan 25, 2011 | Royal 112MX Shredder
Is there a reset button on the Royal VF700 Crosscut Paper Shredder?
No reset button just unplug it or safely lift the top out of the trash can then the Disable/Safety Switch will make it stop (located on the right side towards the back of unit
Jan 13, 2011 | Royal VF700 Cross-Cut Shredder
Royal VF1000mx crosscut shredder jams
Give Royal a call at 1-800-524-0799 they will advise about parts replacement.
Jul 22, 2010 | Royal VF1000MX Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
It will not shred - the reverse works fine
UNPLUG THE MACHINE AND TRY CLEANING THE "EYES" WITH A SOFT CLOTH. IF THAT DOSN'T DO IT YOU MAY HAVE DEFECTIVE EYES OR PCB...YOU CAN CALL ROYAL FOR PARTS AT 1-800-524-0799.
May 21, 2010 | Royal 85X Shredder
Need to replace broken spacer on cutting bar
For parts give Royal a call at 1-800-524-0799.
Jul 10, 2009 | Royal Office Equipment & Supplies
Royal 85X Paper Shredder not working
I have a Royal 10X. Check for a faulty bin interlock.
Feb 01, 2018 | Royal 85X Shredder
Royal 85X Shredder Logo
1,236 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
