Question about Cutler Hammer 1 Pole 15 Amp Ground Fault
How to reset Cutler Hammer 1 pole 15 Amp - Cutler Hammer 1 Pole 15 Amp Ground Fault
  • 760 Answers
Turn handle to off position and then back on. Same as any other breaker. The red test button can be pressed which will trip breaker. If it trips immediately,unplug all devices on circuit and try to reset. Reconnect each device and see which trips breaker. If this goes to outdoor receptacle, check behind cover for moisture.
Posted on Jul 01, 2010
Ge circuit breaker tripping
1. Replace breaker (quick & cheap) ... they do go bad.
2. Find the short.
Jan 11, 2014 | Cutler Hammer 1 Pole 15 Amp Ground Fault
I need a 200amp main westinghouse breaker typecq200ct 2 pole or breaker box b201632cg
You can check home Depot for the breaker, they're compatible with Cutler hammer.
Mar 11, 2013 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Bought a Eaton Cutler Hammer Arc Fault 15 amp Single Pole circuit breaker for my old CH20 model Cutler Hammer CB Box (vintage about mid 1960s). CB package says "Use in Type CH" boxes. It...
I used to run into that being a service electrician all the time Smains! These problems can involve a little more legwork to figure out than some. The best advice that I can give you is, if at that age you can still find a part number on the breaker panel (they renamed them load centers to sound fancy lmao), if you can actually fine a legible one. Write it down and go to Eaton's website, then to load center. They have a parts number search that should take you right to your PANEL lol, and all the specs. I'm not there or if do it for you, hope this helps!!!
Aug 18, 2017 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
How many lights or ceiling fans can I hook up to one 15a single pole circuit breaker.
First of all, are there any other appliances or lights on this circuit? If so, they must be included in the total wattage for the circuit. The fan units are either listed with the Amp rating or wattage rating (Volt Amp) VA. The total amperage allowed on a 15 A circuit is 12A.(80% of the total per NEC). The total wattage would be 1380 watts. ( 115 Volt single phase X 15A = 1725 watts, 1725 x 80% = 1380 watts)
Jan 04, 2011 | Cutler Hammer Ch115 15a 1 Pole Circuit...
Cutler Hammer 20 Arc Fault breaker for bedroom outlets will not reset after activating test switch.
The circuit breaker must be turned to the "off" position first from the middle position, and then to the "on" position. The cutler hammer arc breakers carry a lifetime warranty so if it will not reset you may want to contact the manufacture.
Oct 24, 2010 | Cutler Hammer BR120AF BREAKER CIRCUIT BR 1...
I just tested the breaker and it won't reset. I have other gfci breakers in the panel and they test and reset fine. Is there anything that can prevent the gfci breaker from resetting?
yes. If you still have the fault it will not reset. Disconnect the out going wire to isolate the breaker and try again. If it still doesn't reset then the GFCI breaker is bad and needs to be replaced. Hope this helps you, Jeepfxr
Jan 28, 2010 | Cutler Hammer 1 Pole 15 Amp Ground Fault
20 AMP Cutler Hammer CH GFI wont fit in the breaker box
It will fit, the extra bump out on the back makes it a bit harder to hook the back locking tab before you push it on the bussing. Also, make sure no wires are in the way obstructing the bump out since it hangs out further than the standard breakers. The most common problem is the bump out making it hard to hook the locking tab onto the outer rail. Make sure the breaker is in the off position, then try holding it more flat as you insert it keeping it close to the bussing. This will help keep the extra bump out from obstructing the locking tab from hooking the back rail. Once it's hooked on the back rail you can push it on the bussing like normal.
Oct 10, 2009 | Cutler Hammer CH 15Amp 1-pole GFI circuit...
Swimming pool light on a gfi breaker
It won't take much to trip the GFI. Have you tried to dry the fixture out completely? Use a blow dryer and remove any moisture. Also, remove the light and cap the wires and try it if you can, it might be the wire.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 16, 2009 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Need wiring info for cutler hammer C25DND330 30amp fire shunt breaker...need to shunt 4/220's and 1/110 can you help
Probably easier and about the same price to just buy a shunt trip main breaker. IIRC, code usually requires that anyway.
As far as the c25dnd330, it's just a regular 3 pole contactor, each pole is good for 30 amps. The three poles are L1,2,&3>>>T1,2,&3. The other two contacts are the control coil. I believe your model is 120 volt (most are)....the voltage should be stamped somewhere near the contacts.
Jan 29, 2009 | Cutler Hammer Cutler-Hammer No.BR48L125RP...
Cutler Hammer 1 Pole 15 Amp Ground Fault Logo
328 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Steve
Hippy_dd
Craig Butler
Craig Butler
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
